Duralast crappy u-joint question
Ok I replaced a u-joint a few months ago. I have a ticking sound coming from that u-joint now. BUT, since duralast is crap they put the nipple on the side of the u-joint. I can't get the gun between the slip and flange, so how do I go about greasing it?
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Did you index the joint?
Mark the original grease fittings location and match it with the new one?
Then pump more grease in it after you installed it?
If you have a ticking sound coming from the u-joint, chances are that the bearings in the u-joint are bad, especially if you have been running it dry (with out greasing it). Is it possible to unbolt the drive shaft and angle it so you can get your grease gun on the fitting ?.
Thanks guys! So my fault, just gunna change it out with another one. And make sure I get it right this time!
sharrack
14
Aug 23, 2016 08:39 PM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
priest16
15
Aug 6, 2015 07:43 AM
