Sponsored by: CARiD
rebuild or swap?
Old Sep 30, 2010 | 07:06 AM
db98taco's Avatar
Question rebuild or swap?
ive got a 98 tacoma 4x4 extended cab with a 3.4 v6 in it. a rod bearing just started knockin and im considering a rebuild or an easy swap. i want to have about 230+ hp. can i get that out of a rebuild? ive heard that the 3.4s are just bored out 3.0s and if thats true then i obviously cant do to much on the rebuild. thanks guys
Old Sep 30, 2010 | 07:55 AM
wii_tarded's Avatar
If you do a swap, what engine will you go with? You could either rebuild and add a s/c, or find a replacement engine that already has one. Not sure on hp rating with s/c.
Old Sep 30, 2010 | 07:58 AM
HighLux's Avatar
3.4 is a different beast. Your not going to get 230 naturally aspirated from a 3.4
Personally....Id find another 3.4 and swap it in. Quicker...cheaper...and far less headache than a rebuild or oddball motor swap.
Keep it simple.
Old Sep 30, 2010 | 02:37 PM
844x4's Avatar
I agree you are better off staying with a more stock set up. ITs much easier to find parts later and depending where you live, smog laws get tough with crazy swaps.
Old Sep 30, 2010 | 03:51 PM
theMonch's Avatar
Neither. Find a replacement used 5VZFE motor. Most likely cheaper than the rebuild. Then get the Supercharger and the URD 7th injector kit. You can find 5VZFE (3.4) longblocks on eBay or do a search via google/yahoo.
The stock 3.4 is rated at 190, with the supercharger 260 and with the S/C and the URD 7th kit you can probably get closer to 280 or more with a proper tune.
This will start adding up, probably around 5k by the time the smoke clears.
Old Sep 30, 2010 | 05:22 PM
brian2sun's Avatar
Where are you located at?
Old Oct 1, 2010 | 07:35 AM
db98taco's Avatar
well is there anything i can do internally to the motor since im gonna have it tore down all the way, like cams or stroker kit? instead of a s/c? and if i just put it all back stock besides maybe a little bore will the stock internals hold up to a s/c??? and im located in hickory nc. thanks for all the info guys.
bigjstang
Jun 2, 2025 03:56 PM
dumpster84
Apr 30, 2016 06:03 AM
coleypull15
Nov 3, 2015 07:41 AM
jerusry
Oct 19, 2015 05:28 PM
GeoRoss
Jul 24, 2015 03:03 PM
