What is the operating/overheat water temp for an 02 V6 Tacoma?
What is the operating/overheat water temp for an 01-04 V6 Tacoma? Also a ATF heat Q.
I am trying to find out if someone knows the normal operating water temp range and at what temperature is considered overheating for a 2002 3.4l V6 Tacoma. My temp gauge is broken, but I have a scan gauge and while out wheeling today I got a 251F spike while going uphill. Wondering if I overheated the truck, after it did this I turned the AC off (I know dumb for having it on, but it was dusty and really hot) and the temp doped down and hovered around 190-220 for the rest of the day. Thanks
Also I am running MaxLife ATF which got up to 242F (somewhere around there anyway), do synthetics (MaxLife is) form Varnish at this temp or am I ok? I just flushed and filled, and I am wondering if I need to do it agian after exposing the fluid to this high temp (after it went this high I stopped and let it cool back down, but then it still kept climbing up to around 200-210) I checked the ATF when I got home, and it does not smell burned, and it is still bright red.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
Apr 1, 2018 11:29 PM
TJWilly
Jul 31, 2015 02:05 PM
Poncho0206
Jul 10, 2015 06:21 PM
