Sponsored by: CARiD
gear oil in 88PU 4x4
Old Sep 20, 2010 | 08:32 PM
scott88yota's Avatar
Exclamation gear oil in 88PU 4x4
where do i check my gear oil in my truck. something in my clutch system is messed up i dont think it has been releasing properly and now it is makin this harsh sound and i think im low on gear oil
Old Sep 20, 2010 | 08:33 PM
xxxtreme22r's Avatar
let me get this straight, you think something in your clutch is messed up which led to your front/rear differential/transfercase and/or transmission gear oil to be low?
My thinking on this is low gear oil leads to harsh sounds which is not repairable by adding gear oil. That's like adding more gun powder to an already blow up grenade. It's pointless as there is no grenade left.
but you can learn how to check all of your fluids by clicking on this link
http://www.ncttora.com/fsm/
Old Sep 20, 2010 | 09:02 PM
BigBluePile's Avatar
First I'd look under the truck, not in it....
Old Sep 20, 2010 | 09:05 PM
tthanks man. and you just use reg. dot three in thclutch for fluid right like in the master?
Old Sep 20, 2010 | 09:09 PM
Yes....or whatever manual says.....
Old Sep 20, 2010 | 09:11 PM
thats a big 10-4
Old Sep 20, 2010 | 09:25 PM
so by saying gear oil you are talking about clutch fluid ???
Old Sep 20, 2010 | 09:27 PM
1981 yota's Avatar
of course
Old Sep 20, 2010 | 09:30 PM
so that harsh sound is more like a grinding gear sound than a clunking gear sound. Kind of like if you didn't have the clutch in all the way while trying to shift gears unlike when you blow up a differential and it makes this horrible clunking sound. I think I got it now.
Old Sep 21, 2010 | 11:02 AM
no its not a grinding sound like when youdont have the pedal in all the way. and i was talkin about clutch fluid and gear oil as two different things
Old Sep 21, 2010 | 05:24 PM
Old Mar 22, 2012 | 05:55 PM
carbon's Avatar
i just want to know to post
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
HRDC0R19
Jul 5, 2015 06:43 PM
