Sponsored by: CARiD
98 4runner maintenance
Old Sep 14, 2010 | 12:14 PM
marcel's Avatar
Ok so i have a 98 4runner 2.7L 2WD with almost 160k. so far ive got new shocks and new starter. i want this thing to last forever so is there any preventative maintenance i can do to keep my runner in good shape?
thanks
Old Sep 15, 2010 | 09:07 PM
Ron Helmuth's Avatar
auto tranny? get the radiator replaced....read up on strawberry milkshake.
Timing belt ( or is the 4 cylinder a chain?) and water pump done on time?
just keep paging back-reset the default at bottom of page away from last 30 days...
Old Sep 16, 2010 | 10:50 AM
TheDurk's Avatar
Above is good, plus....
obviously all fluids, including trans, diffs, coolant (& thermostat/WP), TC, brake fluid and power steering. Plugs and plug wires (if original--will say Sumitomo 1998). Inspect brakes (pads, shoes, e-brake operation). Grease driveline. Air filter. Test fan clutch. Clean MAF & TB. Check steering rack bushings and all suspension components--ball joints, sway bar bushings/links, tie rod ends, etc.
You could do O2 sensors if believed to be old or engine not running 100%, or just wait for them to throw codes.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
colinmil
Jul 6, 2015 04:03 PM
