Sponsored by: CARiD
The 3VZE Engine.
Old Sep 1, 2010 | 02:47 AM
JDS1992's Avatar
The 3VZE Engine.
Oka here we go, I hear from everywhere that it is a bad engine..
Any Problems that I should be on the lookout for in the near future?
(139K on Original Engine.)
Besides
-HG (replaced on recall)
Recently Done
-New NGK Plugs
-New NGK Ignition Wires
-New Distributor Cap
-New Serpentine Belts
-All Fluids were replaced within 800 miles ago(except transmission)
-Oil Changed 1,000 Miles ago
-Fuel Injector Cleaner-1,000 Miles ago as well.
-Thanks guys. Heres what Mine Looks like under the hood https://www.yotatech.com/album.php?a...ictureid=13210
Old Sep 1, 2010 | 03:18 AM
Kiroshu's Avatar
Just keep doing the "preventive maintenence" your doing to it in your post and it will run forever.
Old Sep 1, 2010 | 08:07 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
For best results use only Toyota OEM parts on that engine...
T-Belt, tensioner, water pump.
Plugs, wires, cap...
There are no after market parts better than OEM. No starters, no alternators... Nothing.
Old Sep 1, 2010 | 02:07 PM
BackGateYota92's Avatar
its a good motor that will last long if you take care of it and it seems like your taking care of it man
Old Sep 1, 2010 | 02:58 PM
HighLux's Avatar
Ill chime in here. I think the 3.0 is a turd. Everyone ever made fails.
Headgaskets are inevitable. Nightmare to work on. More hoses than a firehouse. More vacuum lines imaginable. Exhaust design fail.
Toyota's first v6 and more than likely worst engine ever from Toyota.
Not trying to be jerky. I just had 2 of em and for me the above applied.
Old Sep 1, 2010 | 03:07 PM
94toyota's Avatar
"Toyota's first v6 and more than likely worst engine ever from Toyota."
that 's not toyotas first v6
if you keep up with your maintenance like the stuff you talked about you can beat on it and it should still make at least 200k
Old Sep 1, 2010 | 03:14 PM
HighLux's Avatar
UH..yes it is toyota's first v6.
Old Sep 1, 2010 | 03:16 PM
HighLux's Avatar
Id say less than 5% of cars are taken care of like they should be.
Id never own a 3.0 again.
Old Sep 1, 2010 | 07:50 PM
yotaman85's Avatar
Many 3vze have gone 200k+. I'm rolling up on 250k on origanal motor.just don't try to make it get more power or MPG, leave it stock and it will take care of you for a long time.
Old Sep 1, 2010 | 08:10 PM
JDS1992's Avatar
Oka thanks guys, I do everything I can to keep it going, and run better,Most of my Money that I make goes to it, on things I can improve, to get it to run better. Its been a great Engine so far hasnt ever let me down. I try to keep it that way. What kind of oil do you other 3VZE Owners run? I run synthetic, because I think its better than Conventional.
Old Sep 1, 2010 | 08:13 PM
joelfiddy3's Avatar
my opinion its an alright engine( for stock tires ) if you dont mind spending a lot on fuel and love spending a whole day on a repair that should take an hour. i agree with yotaman keep her stock, if you do anything advance the timing a little but thats it. I personally have ditched my 3.slow and am running a om617 benz to turn my 36" tsl's and love it so far ;D
Old Sep 1, 2010 | 08:16 PM
Dento77's Avatar
the wife sold her 92 4runner 3.0/5spd to a friend of ours years ago when it had 228k on it. the odometer broke at 356k and he prolly put on another 75k on it before rust took it off the road. maintenance and factory toyota parts go along ways.
Old Sep 2, 2010 | 05:57 AM
krytellan's Avatar
I've never been able to understand peoples' fuel complaints. My '94 3VZE gets on the average of 20.5 MPG on mixed city/highway driving. The '05 Jeep Grand Cherokee I just sold NEVER got better than 16-18.
What are you guys doing (or not doing) to get such horrible mileage? Do you drive like freaks? Redline every shift point?
Old Sep 2, 2010 | 06:09 AM
pwd's Avatar
pwd
I love my two 3vzes, sure they are not the most efficient; but they have never let me down. Both original head-gaskets. The engine bay is tight, but fairly-well layed out. As mentioned above stick to OEM parts and keep up regular maintenance and you should never have a problem.
Old Sep 2, 2010 | 06:31 AM
there was a thread not to long ago debating this. There are tons and tons of yotas with the 3vze that go over 200k no problem. The head gaskets are mainly problems for people who didn't have the recall done. besides only needing a head gasket done every 200-300k miles is really not that bad. Shoot my brothers 2000 ford rangers has had 2 motors put in it already and he only has 140k on his. the same with my dads chevy. if you compare the 3vze to alot of motors its pretty reliable. lol
Old Sep 2, 2010 | 07:13 AM
levsmith's Avatar
Are you sure about that? on fueleconomy.gov, it says the 94 4runner with the 3.0 gets 13 city 17 highway. I dont know how you are pulling off getting 20.5 average. I'm not trying to be a smartass, I'm just a little confused
Old Sep 2, 2010 | 07:18 AM
ET's Avatar
ET
actually, the 3.0 is a decent engine. it's just not what people expect from toyota. anybody ever known someone with a chevy or ford? lol
Old Sep 2, 2010 | 07:33 AM
yotaman90's Avatar
"Everyone ever made fails" - Neither of mine have
"Headgaskets are inevitable" - Same on the 22R
"Nightmare to work on" - It's not that bad. Ever worked on a Mitsubishi Eclipse?
"More hoses than a firehouse. More vacuum lines imaginable" - Worse on the 22R
"Exhaust design fail" - It's not a fail, but it could have been better
"Toyota's first v6 and more than likely worst engine ever from Toyota" - Toyota never has made a "bad" engine. Just because you've had issues with the 3VZ-E doesn't mean everyone else has/will. I've had way more problems from my 22R then any of my 3VZ-E's
Old Sep 2, 2010 | 09:26 PM
JDS1992's Avatar
On mine i get about 14-17 MPGs , and I shift around 2700-3000 rpms depending on the gear/speed Im going.
Old Sep 2, 2010 | 09:29 PM
JDS1992's Avatar
Yeaa American vehicles dont last as long, after about 150-180K Ive noticed that they start to break down, in phases of repairs. From what Ive seen. But I have to give it to Ford tho Their 7.3L Powerstroke Turbo Diesel Engine, Is the one that ive seen turn over 250K
