Sponsored by: CARiD
need help 22re
Old Sep 13, 2010 | 07:23 AM
86Yotaman's Avatar
need help 22re
got an 86 toyota pickup with a 22re. was running fine and i tried to check timing. i jumped what i thought was the check connector and now it wont start just turns over. can anyone please help and also tell me were the check connector is and the diagnostic connector thanks
Old Sep 13, 2010 | 07:26 AM
waskillywabbit's Avatar
Check your engine fuses and fuse box fuses.
Try searching a bit. Tons of info on testing ports.
:wabbit2:
Old Sep 13, 2010 | 05:19 PM
86Yotaman's Avatar
got it figured out the efi fuse was blown. but when i try to jump the pins to get my base timing it wont idle down?
Old Sep 13, 2010 | 05:48 PM
OrRunner's Avatar
i was just reseaching this, and i think that the timing wont change unless your jumping the terminal while the engine is cold. Could be wrong about that, but thats kind of what i gathered.
Old Sep 13, 2010 | 06:04 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Sounds plausible...^^^ That defeats the High Altitude Compensator... IIRC.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
