Sponsored by: CARiD
Is it bad to leave ECT on all the time?
Old Sep 9, 2010 | 02:29 PM
Zelephant's Avatar
I have 265mm tires on my truck with a 22RE and an auto tranny. Basically, I find my truck gets up to speed quicker and cruises easier with ECT button on. My question is, does this cause more wear on the tranny or the motor, or is there another reason it should be used carefully? Also, ECT is supposed to diminish mileage, but it seems I'm on the gas a lot less with it on. Would the bigger tires offset the loss in mileage it has with the stock tires, or am I just imagining things?
Old Sep 9, 2010 | 02:30 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Is it bad to have 500rpm higher shift points all the time?
Old Sep 9, 2010 | 02:34 PM
myyota's Avatar
It won`t hurt anything, it just raises your shift points, and you gas mileage will probably go down a little.
That depends on how many mm's the stock tires were...
Old Sep 9, 2010 | 02:37 PM
Well stock tires were only 711.2... How'd you do that?
Old Sep 9, 2010 | 03:48 PM
brian2sun's Avatar
The higher shift points over time will probably wear your tranny/TC out a little faster, but I have left my ECT on almost continuously for 9 years with no ill effects. As for gas mileage, I personally have never seen a noticeable difference.
Old Sep 9, 2010 | 06:57 PM
Zelephant's Avatar
If 711.2mm equals 29", then your right. I did it by...um...bolting on a set of 3rd gen rims that had that size tire on them. They only rub at extreme steering lock.. It's geared to 4:30, about equivalent to 4:10s on a 5-speed.
Brian: Thanks for the info, makes me feel a lot better about the tranny, but judging by your sig, I'm guessing your 'runner has a V6. Anyone know how the higher shift points affect a 22RE?
Old Sep 9, 2010 | 07:14 PM
peow130's Avatar
28 in = 71.12 centimeters
29 in = 73.66 centimeters
Old Sep 13, 2010 | 08:06 PM
Ninja 85's Avatar
I leave my ECT on all the time now for 3 yrs. I get 2-3 more mpg on the hwy. 6 trips coast to coast not one ounce of troubles
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
