Sponsored by: CARiD
gearing? and lift questions
Old Sep 1, 2010 | 08:57 PM
80toyota's Avatar
i got a 80 toyta 4x4 i got a set of pro comp 33/12.5/15 and i got a 22r and i wanted to kno if i needed to gear the fron and rear for the truck to handle these tires and the tires also hit on a stearing knockle so i would need to life the truck ? i just got into this moved form racing honda on the street to 4x4in and dont kno much about it?
Old Sep 1, 2010 | 09:18 PM
dropzone's Avatar
Fossilized
give the search a try...this has been asked/answered a bunch..
but anyway...4.88 gears, 3" lift, convert to high steer...
Old Sep 1, 2010 | 09:29 PM
80toyota's Avatar
how much do u thin it would cost?
Old Sep 1, 2010 | 09:30 PM
80toyota's Avatar
and were would i get parts from im yelm and tacoma area?
Old Sep 1, 2010 | 09:32 PM
dropzone's Avatar
Fossilized
depends on where you go...I would start googling gears but off the top of my head:
2x gear set $150-250ea
2x master install set $100'ish
the gear Master Zuk charges $250 per set up, you can find it for $150(x2)
--these prices are with you pulling the thirds
Lift prices-vary so much start researching...
call around--you are gonna have to do some of the research yourself...4wheel parts, randy's ring and pinion..east coast gear...etc etc
Old Sep 1, 2010 | 09:40 PM
80toyota's Avatar
okay thanks
Old Sep 1, 2010 | 09:56 PM
80toyota's Avatar
would it hurt the truck tranny or any thing if i ran the tires on there with out the gears?
Old Sep 1, 2010 | 10:14 PM
dropzone's Avatar
Fossilized
no, other than the tiring rubbing on the steering knuckle(probably the draglink) you mentioned...just will feel underpowered....
Old Sep 1, 2010 | 10:26 PM
80toyota's Avatar
year it only hits when i take really really sharp rights
Old Sep 1, 2010 | 10:31 PM
dropzone's Avatar
Fossilized
check your steering stops, sometimes they get crushed
Old Sep 1, 2010 | 10:34 PM
80toyota's Avatar
were would thos be?
Old Sep 1, 2010 | 10:54 PM
dropzone's Avatar
Fossilized
Originally Posted by 80toyota
were would thos be?
oh boy...under each side of the truck (same for both, just reversed) look for a bolt, that as you turn lock to lock, the driver side will contact a triangle looking piece of metal on the front of the axle..(some times those get munched), maybe you just need to adjust yours a little....
here is a picture of mine...(yours will look a little different since I don't have brake backing plates anymore but it points you in the general direction)
sorry--photobucket is down so I can't upload the picture but you will be able to find it in the link below
down load this manual: http://ncttora.com/fsm/1985/1985FSM_OCR.pdf
it says it is for an '85 but the suspension components will be the same 79-85
front suspension starts on page FA-24 for 4WD (page 571 in the PDF)
Old Sep 1, 2010 | 10:56 PM
80toyota's Avatar
okay thank u i know about hondas not toyotas lol
Old Sep 1, 2010 | 11:02 PM
dropzone's Avatar
Fossilized
just like hondas, do your research and you will learn...the FSM link will have a wealth of information for you, it is like a 40 or 50 MB down load but worth it...Good luck!
Old Sep 1, 2010 | 11:14 PM
80toyota's Avatar
thanks
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
