Sponsored by: CARiD
Vibration when 4WD id disengaged...
Old Sep 2, 2010 | 09:00 AM
RePHASE's Avatar
So, I just installed the bilstein 5100 shocks on my 06 tacoma DC. The shocks were set to have a 1.5" lift for the front to level it out. Immediately after install there was a vibration (like a tire rub or cyclical vibration of ridges rubbing somewhere) so I took and double checked the work and nothing was rubbing. Then I started systematically trying to determine where the issue was. As soon as I engage the 4WD the vibration stops, but when disengaged it does it again. I suspected that it might be the alignment, however just had it aligned a few hrs ago and no dice. Curious if any one knows or has any idea what might be the issue.
Old Sep 2, 2010 | 09:08 AM
blake.nemitz's Avatar
probably toed in a little too much
Old Sep 2, 2010 | 09:27 AM
RePHASE's Avatar
I just had a full alignment done, could it be that I need a differential drop with the new lift? I didn't think I would with it only being 1.5"
Old Sep 2, 2010 | 01:52 PM
RePHASE's Avatar
Just took it into the dealer and they said it was most likely a differential, and said I'd be better off spending $2100 to replace it... How hard is it to rebuild a front end diff?
Old Sep 2, 2010 | 03:09 PM
c0ugar69's Avatar
why would it be the front diff if it does it when the front is not turning?? maybe a u joint on the driveline?? does it happen only at certain times and speeds or all the time??
Old Sep 2, 2010 | 03:57 PM
85gijunk4x4's Avatar
cougar is right, the only thing i can think of if it was the front diff, is that the hubs werent disengaging, but then it would make noise in 4x4 also. so i dont think its any of the diffs...
Old Sep 2, 2010 | 04:11 PM
RePHASE's Avatar
Those are great questions, I called the tech and asked the same question, he elaborated that the noise was most likely the bearings in the the diff that took the weight when the 4WD was disengaged. however he'd seen "a lot of metal shavings" when he'd drained the fluid out, suggesting that the gears might or "probably are" worn or bad. He informed me further that since changing the bearings would require breaking the diff out and open, it'd be just as well to rebuild it at the same time.
If any one can call BS on this I welcome it, as I really would like a more precise and cost effective way to solve the issue.
anyone know where to buy a 06 tacoma front diff rebuild kit?
Old Sep 2, 2010 | 04:34 PM
c0ugar69's Avatar
if not in 4wd the diff should not turn, sounds like BS too me. make sure your hubs are unlocked, what speeds and situation is it happening at
Old Sep 2, 2010 | 04:43 PM
vital22re's Avatar
totally a bro
did you get a lift kit? or just longer struts that are made for a 1.5 lift kit?
Old Sep 3, 2010 | 08:36 AM
RePHASE's Avatar
It occurs at pretty much all speeds while in 2WD, however it is the resinates the most at 10mph and 35mph...
Old Sep 3, 2010 | 08:37 AM
RePHASE's Avatar
Just the struts
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Cycles
Sep 29, 2015 06:37 AM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
