Sponsored by: CARiD
carb ? and blocks...
Old Sep 7, 2010 | 02:12 PM
dlgrafton09's Avatar
How can I manually wire a carb wiring harness? The body is EFI so the right plug is not there.
Also, what 22RE blocks and heads are compatible with an '86 22R?
Old Sep 7, 2010 | 02:24 PM
Kiroshu's Avatar
22re is a 22r the head and block will work. 22r and 22re have the same head and block.
Basically...
Difference between and carbed block and head from an EFI is nothing really...
The difference is in the intake and fuel systems among many other things such as wiring and part placement....
Old Sep 7, 2010 | 03:33 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
85-94 are the same.
http://www.lcengineering.com/TechNotes/?techid=49
Don't mix and match pre 84 and post. The deck heights changed.
Old Sep 7, 2010 | 05:37 PM
We can't figure out the knock this engine has so we're gonna swap with the EFI engine and frankenstein something that will run...tomorrow...should be fun...
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
