Sponsored by: CARiD
start and electrical problems
Old Sep 23, 2010 | 02:49 PM
Un5p0k3n's Avatar
Unhappy start and electrical problems
ok im new to the site and to the truck.. i have an 86 4x4 pickup with the 22r i went out off roading last night a bit and got stuck in some mud then my truck started to sink long story short i took on some water in the cab.... everything was fine untill this morning i went to start the truck and it wouldnt start i checked all the fuses and connections cleaned everything even the grounds then tried and all it did was click.. i was able to push start it so i figure that problem is just the starter cuz i had the same problem with my supra at one point.. any way once i got it started my charge and break light were both on and my radio cut out for a second ive read a little bit about this problem on here but not to sure what to look for to fix the problem.. my batt is 100% checked it with a batt charger. im thinking alternator maybe or could it be a short in the cab from getting water in there? i dunno im not used to carb trucks or these trucks at all since most of my time goes into working on my supra
Old Sep 23, 2010 | 03:01 PM
Irish Death's Avatar
if its your brake and charge light its your alternator...
Old Sep 23, 2010 | 04:10 PM
xxxtreme22r's Avatar
the alternator would not cause the truck not to start. check the small positive wire that comes off the battery cable that goes into the fuse box. also check the fuse for the charge system. I believe it's a 7.5amp fuse in the same fuse box under the hood.
Old Sep 23, 2010 | 08:29 PM
Un5p0k3n's Avatar
yeah figured out the not starting problem.. i guess when i was out mudding my starter got all full of mud when i sank so i had to bang the dirt out and clean it up works like new.. charge and break light still on and figure that its the alt based on everything ive read on here.. thanks alot for the suggestions.. sorry if i end up asking a lot of questions on this site its set up alot different than the other forums im a part of.. once again thank you..
Old Sep 29, 2010 | 06:15 AM
Un5p0k3n's Avatar
ok so i checked all the wires and such nothing is lose any more i even replaced the brushes on the alternator still nothing i dont know what to do im broke as all hell and i just filled the tank in my damn truck before it died.. what am i missing what should i be looking for? also now the oil pressure light isnt coming on any more when you first turn on the truck
Old Sep 30, 2010 | 02:33 PM
844x4's Avatar
Once I got my 84 so deep in the mud that all the silt stirred up and got into the alternator and starter killed everything all dash lights were on.
I had to replace the alt and starter and everything was fine. But if you are good you may be able to clean the parts out?
Regency
20
Jan 3, 2020 07:43 PM
noahstancik
Jul 10, 2015 11:18 AM
bigblue82
10
Jul 6, 2015 08:27 AM
aciorba23
Jun 29, 2015 04:18 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
