Have to do slave w/ clutch master?
OK ..... Im getting ready to go wheeling for a long weekend tomorrow and have been puting off replacing the clutch master cylinder. Ive done a search and have not got a deffinate answer. My clutch master has been leaking for a while but performance has been fine. I have a new aisin one but did not get a slave. Do I have to replace the slave at the same time even though it is not leaking or can i just do the master? Thanks for your guys time
Brian
Brian
Please read the Factory Service Manual for install instructions
www.ncttora.com/fsm
Typically for no more than they cost slave and MC are replaced together.
www.ncttora.com/fsm
Nice to see another local member. Where you going wheeling?
Its a very good idea to do so. I've seen a lot of instances where it was not done and the slave cylinder will fail if not changed with the master cylinder.
Thanks guys.....Ill run down to the dealer and see if I can scrounge up a Aisin slave. I actually just moved to Charleston, SC from Roanoke but Im here right now at my Brother's getting ready to head to the Big Dogs main jambo in Winchester tomorrow.
BigHoss_27
Sep 21, 2015 07:44 PM
