Sponsored by: CARiD
gnarley vacuum leak
Old Aug 26, 2010 | 06:18 PM
vitamint's Avatar
gnarley vacuum leak
I was driving home the other night and I heard a noise from under the hood, kinda like a bang... I was able to drive home ok, but I heard this loud vacuum leak. I looked under my hood this morning, and I noticed this part missing, and I am trying to figure out what it is and where I can get it
The part in question is the hole that has the vacuum cap on it in the bottom left of the pics. I put a hectagon around it... THANKS!
Old Aug 26, 2010 | 06:30 PM
95blackToy's Avatar
cant see anything. Got a larger picture?
Old Aug 26, 2010 | 06:55 PM
Fireball81's Avatar
I can't see it either but if you have a manual the best place to start looking is probably the emissions diagrams. Where they show you the sensors and the vacume line routings....Or post a larger pic for us. Good luck.
Old Aug 27, 2010 | 01:36 AM
vitamint's Avatar
Better pic of the problem
OK ... here we go... This is a MUCH better pic... I highlighted where the missing part should be
Old Aug 27, 2010 | 11:59 AM
95blackToy's Avatar
wow i have never seen something like that happen. I think it is normally just plugged up or something. Does it run fine beside idling bad from the leak. Might try starting it up and putting your finger on it and see what it does. Id probably just cap it off till i was sure what it was.
Old Aug 27, 2010 | 12:10 PM
gradyblownglass's Avatar
hole
oooooohhhhhhhhhh yes that is the location of the idle adjustment screw. i was thinking of a different t.b.
Old Aug 27, 2010 | 01:57 PM
Fireball81's Avatar
There is supposed to be an adjuster screw there for your idle. Don't ask me what it's called but I have one in mine and when I tighten it my idle drops and when I loosen it the idle raises. I'll get a pic of mine on here asap.
Old Aug 27, 2010 | 02:34 PM
ChefYota4x4's Avatar
That is VERY important, and you don't want to simply plug it up. It's the "Idle/Air Adjustment Screw", which has an o-ring toward the bottom. You'll not find it at the dealer(I've tried), ...not even the O-ring... but you can get one to fit at Napa or something like a specialty Auto parts/hardware store. If so, make sure it's aluminum friendly.(Personally, I'd be hitting the junk yard). Only problem ,now, is WHY did it pop out? Either the threads are completely gone(not likely) or the o-ring dissolved and the thing just backed itself out by vibration(my guess).
Call your local yard and ask for one. They might not separate it from the throttle body.
JNapolitano
Nov 14, 2019 07:46 PM
wafoogalla
Nov 2, 2016 11:02 AM
raptor510
Aug 19, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
nick b
Jul 11, 2015 04:38 AM
