Sponsored by: CARiD
22RE crate motor?
Old Sep 23, 2010 | 08:02 AM
palerider39's Avatar
22RE crate motor?
Just bought a 92 4x4 truck, needs an engine. Bought as a project for son and myself to build. Looking for a crate motor to install. any suggestions on a good company to buy from. Thanks
Old Sep 23, 2010 | 08:08 AM
dropzone's Avatar
Fossilized
Lc engineering, Oregon engine builders etc.
If you come across DOA, do lots of research on them and come to your own conclusions
Old Sep 23, 2010 | 10:12 AM
saitotiktmdog's Avatar
LC Engineering
Old Sep 23, 2010 | 10:15 AM
VANCE164's Avatar
oregon enigine doesnt do a crate motor if im correct all I could buy from them was a long block
Old Sep 23, 2010 | 10:51 AM
iselloil's Avatar
I had mine built from Sunwest. Since I installed it three years ago,I've not had any issues,or repairs with the motor.
http://www.sunwestautomotiveengines.com/
Old Sep 23, 2010 | 10:53 AM
myyota's Avatar
www.22reperformance.com
Old Sep 23, 2010 | 10:58 AM
A.Wilson013's Avatar
Originally Posted by iselloil
I had mine built from Sunwest. Not the first problem.
I also got mine from Sunwest. What do you mean "Not the first problem"?
Old Sep 23, 2010 | 11:15 AM
iselloil's Avatar
Meaning no problems with the motor.It has worked just fine since the install three years ago,
Old Oct 19, 2010 | 08:14 AM
Thanks for all the suggestions guysd, I got an engine from oregon engine builders, about halfway through the install and doing good. need to find gasket that goes between the heater hose and the intake...wasn't in the gasket kit that came with the motor, any Ideas?
Old Nov 3, 2010 | 07:54 AM
oil at break-in?
What oil is bestr for break in? I understand no synthetic, and no fram filter. Was thinking castoroil GTX 10-40. suggestions please.
Old Nov 3, 2010 | 07:59 AM
xxxtreme22r's Avatar
valvoline 10/30 is what engnbldr recommended to me and after the first 3000 miles I switched to the valvoline 15/40 and also use rotella 15/40. He rec'd the valvoline because of it's higher zinc content than any other oils on the market. As far as filters go, the thread on here talking about filters and whatnot convinced me to use the pureone filter.
he also rec'd that i change after the first 30 minute or so break in again at 500 miles and again at 1500 then at 3000 and every 3000 after that.
Old Nov 3, 2010 | 09:43 AM
iselloil's Avatar
10w-30 For regular use I run amsoil 10w40 for the flat tappet.
Old Nov 3, 2010 | 09:45 AM
iselloil's Avatar
Filters, look at youtube whaere the guy pulls all the brands apart,then make up your mind.
Old Nov 3, 2010 | 10:19 AM
yoder519's Avatar
put nothink but a toyota oil filter on it my friend. thats the best thing you can do for that new truck
cars-guy
Aug 16, 2020 06:59 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
garagespace
Jul 9, 2015 08:37 AM
