Sponsored by: CARiD
lower tcase gears or in my axle
Old Sep 6, 2010 | 07:23 PM
Rtzfb36's Avatar
I hav a 85 pickup, and I was wondering if I should put lower gears in my transfer case or lower gears in my axels first. I do drive this truck on the street alot, but im not needing any help turning the tires on the road im just wanting a lil more power on the trail. Does anyone have any advice on which one i should go for first?
Old Sep 6, 2010 | 07:29 PM
2DoorRunner's Avatar
What tires and gears do you have?
Old Sep 6, 2010 | 09:13 PM
dropzone's Avatar
Fossilized
welcome to yotatech>
lower transfer cases are only available for low range, they won't affect high range so I would recommend that you regear your thirds first.
33's=4.88 gears
35 & 37's=5.29's.
Gear for what size tire you are gonna plan on running, no sense is paying for it twice.
and think Solid Pinion Sleeve, not a crush sleeve
a lot of the answers you are gonna think of have been asked before...search and you will learn
Old Sep 6, 2010 | 09:42 PM
BigBluePile's Avatar
I don't use 5.29's.......
Old Sep 7, 2010 | 01:00 PM
Big Paul's Avatar
Re-gear the axles most definetely
Old Sep 7, 2010 | 01:16 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
axles... Now, to the next silly question...
Old Sep 7, 2010 | 06:38 PM
Rtzfb36's Avatar
im using 32x11.50s right now n i hav 4.10gears in it. I'm normally only in highrange on the road thats why i didnt know if i should just go with the tcase gears since it only affects low range.
Old Sep 7, 2010 | 06:41 PM
yotaman85's Avatar
you beat me to it..
as for the question, re-gear the axles.
Old Sep 11, 2010 | 06:15 PM
whokrz's Avatar
If you are happy with your current tire size and the power on the street it does not make sense to change the gears in your differentials. When you are no longer happy with street performance then look into gears for the differentials.
Changing the gears in you transfer case will give you a lot more torque when you are in 4low. It will also allow you to drive much slower which is nice for control. If you have a manual transmission the clutch won't struggle anymore. The only problem with changing the transfer case gears to 4.7 is that your top comfortable speed in 4low will be around 15mph.
Old Sep 11, 2010 | 07:15 PM
muddpigg's Avatar
You can also do 4.0 in the t-case.
What do you plan to do with the truck?
Old Sep 11, 2010 | 07:19 PM
You really don't have 4:10's running those 32's... You had 4:10's when you were running the factory 28".
To find out your effective gearing minus .10th of the gear per inch you went up on your tire.
That's why speedo's are off and the truck don't have power b/c the truck's now out of its peak torque curve...
Old Sep 11, 2010 | 07:29 PM
muddpigg's Avatar
Are you just buffering post count or what. The diff ratios didn't change, yeah their effectiveness in turning the tires did but never did the dif ratios change.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
PlayAwhile
Jul 20, 2015 11:36 AM
