Sponsored by: CARiD
newbie with a ?
Old Oct 7, 2010 | 05:56 PM
mikesyota94's Avatar
Exclamation newbie with a ?
hello everyone i am new to the toyota scene. but love it so far! i have a 94 toyota pickup with the 4cyl 4x4. i love it. ihave an issue im trying to resolve with my 4wd. the front differential is making a clunking noise and the passenger axle doesnt move when in 4wd. i am going to replace the differential and my question is what is my gear ratio for the front diff so i can buy the right one its a 94 regular cab 5 speed with the 4cyl (22r?) has manual hubs. i am also in the market for a differential i am located in the youngstown ohio area. thanks in advance.
Old Oct 7, 2010 | 06:35 PM
myyota's Avatar
Look on the plate mounted on the driver side door opening, it will what gears you have.
Old Oct 7, 2010 | 06:38 PM
ChefYota4x4's Avatar
Doesn't move as in, 'Dragging on the ground while the other spins mud'?, or as in, 'Rolling but not LITERALLY engaged and driving in 4wd'?? Be sure it's your diff and not just a snapped or tweaked axle(or LOCKED up Hub) before going through all that.
Far as the gears, I think a couple guys on here will have the answers, but I'm pretty sure they're 4:10's, stock, even on that year. The front and rear gears HAVE to be the same, or you will have issues.
If it's Fuel Injected, it's the (22re), to answer your other question.
Nice to meet ya, and welcome to Yotatech! Best wishes on the troubleshooting!
Mark
Old Oct 7, 2010 | 06:40 PM
clydehatchet's Avatar
http://home.4x4wire.com/erik/diffs/#hipinion
http://www.brian894x4.com/Gearratiosanddiffs.html
http://www.grimmjeeper.com/gears.html
http://www.ncttora.com/fsm/
Welcome to YT
Old Oct 7, 2010 | 07:26 PM
i put it on jack stands and put it in 4wd and in gear and crawled under it and the axle was moving up and down side to side like it was just sitting in the differential and u can move it around with ur hand. but its like the passenger axle isnt attached to anything in the diff then it will catch and make a clunk noise spin a half turn and stop and start wiggling around again. thanks for the info guys and i just put brand new warn hubs on it today that was my first guess on what was wrong until i further investigated. maybe i will pull the axle this weekend and see if its broken.
Old Oct 7, 2010 | 07:36 PM
vital22re's Avatar
totally a bro
drop the diff and the pull the front cover and take some pics. We'd like to see the carnage.
Old Oct 7, 2010 | 07:38 PM
haha ok i will take some pics when i swap them out. im really curious on what actually broke.
Old Oct 8, 2010 | 01:47 PM
Ok so i looked up the numbers on my door and found that its b03a so this means that i have a 8" ring gear with 4:10 ratio and open diff is this correct?
Big Little Bear
230
Nov 13, 2023 11:42 AM
JonG85
Jan 18, 2023 04:31 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93RedKrawler
Sep 29, 2015 02:50 PM
