Sponsored by: CARiD
pcv valve parts question
Old Sep 11, 2010 | 09:21 AM
needayota's Avatar
hey all,
i searched the pcv valve threads and think i have the answer but could someone confirm or deny?
OK, 94 22re rebuilt 10k ago. compression is good, no leaks anywhere of any fluid. uses alot of oil with no visible smoke from tail pipe. there is an oil smell that is apparent when im at a stop after driving though. when i took it to a mechanic they replaced the pcv valve AND the gasket! so right now my pcv valve and hose have oil in them (fresh looking) and i can lift the pcv valve out of the new rubber gasket they installed with extreme ease! the rubber gasket comes out very easily as well leaving the big hole there.
my pcv valve rattles so i dont think its shot though im replacing it anyways.
my questions are:
would these circumstances cause massive oil consumption?
what is the name of the CORRECT OEM gasket so i can order this along with an OEM pcv valve?
from what i remember about the PCV valve is that it doesnt come out of the VC easily (i had use to use pliers and alot of force). correct?
thanks for reading and i hope someone replies!
thanks!
Old Sep 11, 2010 | 09:25 AM
A.Wilson013's Avatar
If your gasket is new, it won't be that hard to pull out.
Granted, it should not be as easy as if you were just picking it up off the table.
I don't think that those circumstances would cause MASSIVE oil consumption though...
Old Sep 11, 2010 | 09:30 AM
needayota's Avatar
what about the fact that there is oil on the other side of the valve though? is it typical to let some oil through?
Old Sep 11, 2010 | 09:34 AM
Take the valve out, shake it, does it rattle?
I am not a mechanic, so if anyone is able to see error in what I say, correct me.
The PCV is supposed to route partially burned gases back into the engine.
I don't believe that fresh oil has any business in there...
Old Sep 11, 2010 | 05:23 PM
whokrz's Avatar
Here is the route the air takes per the factory service manual. http://ncttora.com/fsm/1990-1995_4Rn...n/positive.pdf
I am assuming that you still have the shield on the inside of the valve cover.
Old Sep 12, 2010 | 10:24 AM
Haha, I was assuming that as well. Without that shield, yes, you may have quite a bit of oil going through that valve.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
