Sponsored by: CARiD
Timing chain woes
Old Sep 27, 2010 | 06:34 PM
v45willy's Avatar
Timing chain woes
HELP!! Think I broke a timing chain.. the rotor is still turnng but it seems to be turning slower than it should. The truck just shut down in my driveway (1st time ever). at #1 TDC my rotor is a couple of clicks off ( I believe on the #4 cyl)?? the starter seems to be turning high rpms and the engine not so, it seems to have no/little compression. My fear is I have bent vlaves or piston damage, any way of telling w/out pulling the head?? Not a ace mechanic but willing to learn. It was just idling when it died I have only cranked it for a few times since.. Does it matter?? INPUT PLEASE!!
Old Sep 27, 2010 | 06:36 PM
HighLux's Avatar
dont have to worry about pistons hitting the valves in a 22re
Old Sep 27, 2010 | 06:37 PM
HighLux's Avatar
rotor wouldn't turn if the timing chain was broke
Old Sep 27, 2010 | 06:55 PM
toyospearo's Avatar
sounds like the cam timing is off..
Old Sep 28, 2010 | 04:33 PM
v45willy's Avatar
need answer on timing problem
1986 4x4 truck just quit running I turned the crank around to TDC the #1 cyl. was on #3 on the rotor. Is it common for this to happen? And just what exactly did happen, what qualifies for the term jump time? Did I shear a tooth on the crank or cam sprocket? Can I adust the time back by the distributor? What are the possibilities of valve damage or is it pretty much a combo deal when it jumps time the vlalves are bent? And how will I tell if the vlavles are bent any way of knowing while I have it torn down. Some one please give me some step by step what to do first, really dont want ot spend $900 to have it done by a shop but dont want to get in over my head I do have a garage and tools, but my mechanic ability has been more toward starters,fuel pumps and water pumps etc... briggs and stratton and such!! Am I just letting this become much more difficult than it really is. or are my concerns justified? To a fellow who is very unfamiliar with the internals of a auto-engine if I decided to get wet would I drown or would I be okay? Any first timers that were in my shoes at one time? wait'n for reply
Old Sep 28, 2010 | 04:38 PM
HighLux's Avatar
Alot of questions.
Top dead center on the compression stroke. you are 180 off on tdc.
What happens right now if you try to start it?
BTW non interference engine=no valve damage if chain fails.
Old Sep 28, 2010 | 04:52 PM
v45willy's Avatar
This is a 22re stil a non-inteference engine? I Have heard both calls here on this forum dont know which way to lean I certainly would hope no valve damage.With all respect do you know this for certain?? THANKS
Old Sep 28, 2010 | 04:55 PM
HighLux's Avatar
Yes. Fact.
Old Sep 28, 2010 | 04:56 PM
HighLux's Avatar
Now lets get back to answering...what happens when you try and start the toyota?
Old Sep 28, 2010 | 05:14 PM
v45willy's Avatar
Sorry.. The starter turns alnost a whine, the engine does not seem to be turning as it should (quick enough) the rotor is turning but it does not fire or act as if it even wants to start.
Old Sep 28, 2010 | 05:22 PM
HighLux's Avatar
is the valvetrain spinning?
Old Sep 28, 2010 | 05:30 PM
v45willy's Avatar
I hav not taken the cover off or done anythng it is still sittng where it went down, I would have to take off valve cover to find out correct?? bear with me here, Im slow but I am sure.....
Old Sep 28, 2010 | 05:32 PM
HighLux's Avatar
Yeah...pull of the valve cover and have someone crank it over....we will know right away if you broke the chain.
Take ya 10 min at best....
Old Sep 28, 2010 | 05:34 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Ok, 1st off this engine IS a positive interference motor. That means YES, the valves can hit the pistons. I can link you a case a chain broke in a position they never hit the pistons, but won't bother b/c all you'll find out is what I just told you.... So NEVER assume just b/c you think they hit, they did. You must rule this out with troubleshooting.
2nd, there are TWO Top Dead Centers on this engine. The same mark is used for both TDC and B-TDC. So you might have gotten #3 confused with #4 and just had the engine at B-TDC.
3rd, you need to remove the valve cover. This will let you visibly inspect the major components associated with the timing.
Anything broke or missing is self explanatory.
4th, time to bust out the Chilton's or FSM. Search google, or the FAQ's here and see if there's a place you can down load one.
The FSM is the best, well that too should be self explanatory b/c it's the book Toyota wrote for the Toyota techs.
http://www.google.com/search?sourcei...986+toyota+fsm
Last edited by tried4x2signN; Sep 28, 2010 at 06:08 PM. Reason: engine, not truck...
Old Sep 28, 2010 | 05:36 PM
v45willy's Avatar
I can do that, if so and the valve train is turning how does one explain the timing? How would I correct it..
Old Sep 28, 2010 | 05:40 PM
HighLux's Avatar
22re pistons are dished...the valves do not hit...this guy has not done his research.
Go see if the valve train is spinning and we will go from there.
Old Sep 28, 2010 | 05:42 PM
v45willy's Avatar
GREAT... I was just informed that it is a fact the 22re is a non-inteference engine, but you sound like you are well informed and have your ducks in row,,, hoped for the opposite, how can i truly get #1 TDC?
Old Sep 28, 2010 | 05:43 PM
Oh, easy! Just make sure the cam dowel is at 12:00 with the crank pulley indicating TDC and the distributor is pointing at the #1 wire.
You can further back this up by seeing a timing chain replacement section of an FSM...
Or, I can just link you one
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
http://www.4x4wire.com/toyota/maintenance/timingchain/
Old Sep 28, 2010 | 05:44 PM
Nope sorry... DISHED? Is that all you got? (lol) That don't mean a dang thing!
The 3.0 is the non-interference, not the 22R/E.
Old Sep 28, 2010 | 05:45 PM
HighLux's Avatar
well when you have the valve cover off to see if the chain is broke.....you can watch the valves on #1 when you line it up at tdc on the crank. valves closed on tdc mark is what you want.
