Toyota 22R
what do you need to know?
81-82 blocks had taller deck heights and dual row timing chains, 83-84 had taller deck heights same as 81-82 but had single row timing chains, 85-on engines had a shorter deck height and flat topped pistons with single row chains.
you can also look in the spark plug holes and see which pistons it has.
I believe the valve covers were different between the 81-84 and 85-on, just not sure on the years.
EDIT: to make it more readable:
81-82 taller deck height ...... domed pistons ......................... dual row timing chain
83-84 taller deck height ...... domed pistons same as 81-82 ... sing row timing chain
85-95 short deck height ...... flat top pistons ......................... sing row timing chain
Nooooo, 81-84 had short deck heights with domed pistons and 85-95 had tall deck heights with flat topped pistons. And yes, the valve covers are different between the two
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Noooo, the 20 and 22R up to 84 had TALLER deck heights. The 22R was de-decked in 85 and was discontinued (in the US anyway) in 95 when the Tacoma took the Mini's place.
Making the de-decked 22R/E production run from 85 to 95.
lol, sorry guys...
http://www.lcengineering.com/TechNotes/?techid=49
lol, sorry guys...
79-84 And 85-95 will not interchange.
The block deck was de-decked in 85. So you cannot and should not interchange the heads.
85-95... Blocks are all the same (Ex Turbo) Semi-flat topped pistons. Have a slight dish.
79-84 blocks are easily ID'd by the high top pistons.
Here's a RE cover on an early 22R block
lol, sorry guys...
lol, sorry guys...
EDIT, dang it did it again, I see what you mean now, need coffee. lol. I will re re edit. hahaha.
Sorry, Ex. But this is what's confusing me.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
