Toyota 22R
Old 10-06-2010, 01:02 PM
bob nob's Avatar
Question Toyota 22R
Are you able to identifiy the year and make of engine by the block numbers? Is there any other source of identifing engine?
Old 10-06-2010, 01:07 PM
xxxtreme22r's Avatar
what do you need to know?
81-82 blocks had taller deck heights and dual row timing chains, 83-84 had taller deck heights same as 81-82 but had single row timing chains, 85-on engines had a shorter deck height and flat topped pistons with single row chains.
you can also look in the spark plug holes and see which pistons it has.
I believe the valve covers were different between the 81-84 and 85-on, just not sure on the years.
EDIT: to make it more readable:
81-82 taller deck height ...... domed pistons ......................... dual row timing chain
83-84 taller deck height ...... domed pistons same as 81-82 ... sing row timing chain
85-95 short deck height ...... flat top pistons ......................... sing row timing chain
Old 10-06-2010, 02:24 PM
yotaman90's Avatar
Nooooo, 81-84 had short deck heights with domed pistons and 85-95 had tall deck heights with flat topped pistons. And yes, the valve covers are different between the two
Old 10-06-2010, 03:11 PM
thanks yota,, note to self, don't spend 10 hours on yotatech reading newbie posts, my head hurts, haha, edited above. I know better than what I posted haha.
Old 10-07-2010, 08:10 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Noooo, the 20 and 22R up to 84 had TALLER deck heights. The 22R was de-decked in 85 and was discontinued (in the US anyway) in 95 when the Tacoma took the Mini's place.
Making the de-decked 22R/E production run from 85 to 95.
lol, sorry guys...
http://www.lcengineering.com/TechNotes/?techid=49
Originally Posted by tried4x2signN
79-84 And 85-95 will not interchange.
The block deck was de-decked in 85. So you cannot and should not interchange the heads.
85-95... Blocks are all the same (Ex Turbo) Semi-flat topped pistons. Have a slight dish.
79-84 blocks are easily ID'd by the high top pistons.
Here's a RE cover on an early 22R block
Old 10-07-2010, 08:20 AM
lol, sorry guys...
I thought that was already cleared up? and that's what my post now reflects above? Maybe when I split the 81-82 and 83-84 styles confused you too? Maybe I will re write that to make it more readable and understandable.
EDIT, dang it did it again, I see what you mean now, need coffee. lol. I will re re edit. hahaha.
Old 10-07-2010, 08:26 AM
Sorry, Ex. But this is what's confusing me.
Old 10-07-2010, 08:27 AM
Me 2
Old 10-07-2010, 08:31 AM
Me 2
ok all fixed now (except for the coffee), I swear I know better than what was posted twice by myself. grrrr....
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
nick b
07-11-2015 04:38 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Toyota 22R
