Sponsored by: CARiD
Whats going on with my spark plugs?
Old Aug 26, 2010 | 12:35 PM
dhall50's Avatar
I have ran these plugs since June after a new head gasket. Maybe 500 to 1000 miles. The First and worst is from the first cyl. Rest don't look so bad. This is on a 1986 22R with a Weber Carb. Thanks. Also plugs are NGK R BPR5EA-L Is this the correct plug?
Old Aug 26, 2010 | 12:48 PM
1990yota-pickup's Avatar
step down to a cooler. plug..
xxxtreme22r's Avatar
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
Old Aug 26, 2010 | 12:49 PM
Deposits
The accumulation of deposits on the firing end is influenced by oil leakage, fuel quality and the engine's operating duration.
Old Aug 26, 2010 | 12:54 PM
iamsuperbleeder's Avatar
looks like you're burning a little oil
did you change your valve stems seals while you had the head off? how many miles are on the head?
Old Aug 26, 2010 | 12:56 PM
dhall50's Avatar
The machine shop installed new seals after they straightened the head and re seated the valves. They came with the engnbldr gasket kit. Since it was redone? 500-1000. The truck its self has 236,000 so who knows the history of the the head. A little oil is fine(it doesnt smoke) but i noticed most of the plugs are kind of white as well. Should I replace with a colder plug or?
Old Aug 26, 2010 | 12:59 PM
new PCV valve with the rebuild too?
if it's clogged, it could be sucking oil into the intake
if not, I'd say yeah try a colder plug
my guess he's just got some blowby from the rings pressurizing the crank case and the oil is getting sucked into either the carb or the PCV system. or the pcv valve is stuck open.
dang it bleeder beat me to it by like a second lol
Old Aug 26, 2010 | 01:10 PM
dhall50's Avatar
Two observations after oil leak statement. Weird for it to be out of the hole like that right? Maybe oil from a past job?(Just did timing chain) Maybe not torqued properly? What do you torque yours to?
Old Aug 26, 2010 | 01:12 PM
dhall50's Avatar
Thanks guys. I will get a new valve and colder plugs and see where we end up.
Old Aug 26, 2010 | 07:14 PM
just use stock plugs, but definitely replace your PCV valve if you didn't do so during the rebuild; that may be all it is
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
