PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Sound Dampening: what works, what doesn't?
  2. Toyota Chinook Floor Replacement
  3. looking for some Rust advice for my 83
  4. Broken bolt can't find replacement.
  5. Dual shocks setup
  6. 1983
  7. High oil Consumption at 47K
  8. Alternator light turns on when started
  9. Stabilizing "western style" side mirrors
  10. Heater diagnosing
  11. 1979 Pickuop 4x4 Parts catalogue?
  12. 1979 Pickuop 4x4 Parts catalogue?
  13. Coolant leak front of engine 22R
  14. 7.5 8.0 pinion flange
  15. Mechanical fuel pump interchangeable
  16. Leaf spring recs.
  17. Building an 81' Yota with my Wife's Dad (Photo Heavy)
  18. 1983 Shortbed 4x4 Pickup Fuel Tank Replacement
  19. Moister coming in the door panel
  20. Truck wants to stall under heavy breaking
  21. Stock height front leafs
  22. Engine dies when warm and on freeway 82 4x4
  23. Base to sr5 cluster swap
  24. 1980 pickup charging issue
  25. Rust repair on 77 hilux
  26. Stock fender flare prices
  27. Moonroof Pictures Request help
  28. ISO Tailgate for 83' Pickup 4WD
  29. Adding PS to non-PS truck
  30. 79 4x4 fuel sending unit electrical rubber boot(?)
  31. Turn signals Stopped working
  32. turn signal woes
  33. Rust converter that will dry clear?
  34. OM617 swap engine bay pics
  35. 20r Rebuild?
  36. Build Help
  37. Door key turns counterclockwise
  38. 1983 Toyota 4x4 Pickup - Long bed
  39. Windshield gasket
  40. Weber dumping gas, stuck float?
  41. Toyota Manuals
  42. Waiting on my truck to arrive
  43. Power Steering conversion 81 Pickup
  44. Portable abrasive/sand blasters?
  45. 1979 4x4 long bed Exhaust System?
  46. Charge light stays on.
  47. Varying idle speed on startups
  48. 0" OME lift?
  49. 20r funky idle
  50. Engine oil smells like gas.
  51. Best tranny fluid for 79 4x4
  52. 1982 pickup stalling after warm
  53. W40 Trans
  54. 82 4x4 stock steel wheels
  55. Front leaf spring replacement
  56. How difficult to repair this
  57. grill emblem restomod
  58. W50 to W55 swap
  59. 82 4x4 front end shimmy at 50-60mph unless accelerating
  60. 16 in wheels?
  61. Building 20r
  62. Broken Hub repair
  63. Split rings?
  64. What’s going on in these pics
  65. 21r?
  66. Converting back to pickup
  67. 1st Gen changes by year
  68. Are these stock Toyota wheels?
  69. Febuary 1, 2011
  70. A/C Amplifier Wiring Qs:
  71. Will This Wheel and Tire Combo Work?
  72. Gas Fill Inlet Flange Removal
  73. GM alt bracket
  74. Need help with stalled project 1981 Hilux
  75. 1/2 Ton or 3/4 Ton??
  76. 1982 Diesel Injection Pump repair?
  77. Side Marker Lights
  78. Need help identifying this part
  79. Shifter Boot help for 1983 SR5 2WD
  80. Weber 32/36 fuel return line.
  81. 1979 Tail Light Circuit Issue
  82. SOS! Rear Diff (Third Member) bad, What will will swap in?
  83. 1980 blower motor relay wiring
  84. Rewiring 77 pickup
  85. rebuilt motor, black smoke
  86. 1983 Truck 4WD Deluxe will not start
  87. Help wiring Tach..
  88. 1981 Toyota pickup charge problem
  89. 22r Desmog, Aisan Carb: what is the vacuum port with the rectangular cover?
  90. Spring advice
  91. De Smogged Charcoal Can
  92. 22r With Mysterious Rough Idle - Electrical?
  93. My fiberglassed dash project
  94. Seeking new or NOS A/C Amplifier for 79 4x4 truck
  95. Frame repair questions
  96. 82 4x4 instrument cluster
  97. 3D Scan or Print Interior Parts?
  98. 77 help charging issue
  99. Aftermarket fenders and hood.
  100. Aftermarket Fuel Sending unit..
  101. Steering shaft ujoint
  102. 22RE swap
  103. Smog exemtion for 83 and older in cal.
  104. RUF questions
  105. Aftermarket Gauge locations
  106. 1979 Windshield Repair and Replacement
  107. turn signal trouble shooting
  108. Door weatherstrip part identification needed
  109. 1975-1978 Pickup Electric Fuel Pump Wiring Diagram & Info
  110. Booger
  111. 82 rdw manual steering help
  112. Need help with aluminum radiator for a 1980 4X4
  113. Q regarding O-rings for R12 to R134 AC Conversion
  114. 1979 Toyota with 15 inch rear wheels
  115. 79 Toyota 15 inch tires
  116. 22R Fuel Pump Bolts
  117. '82 is cold blooded..bad
  118. 82 4x4 smog
  119. GM Ignitor Swap Hard Starting in Cold
  120. Repair Nightmere
  121. auxiliary electric fuel pump for weber?
  122. Need head for 1980 20R
  123. Weber carb electric choke
  124. Webber 32/36 Electric choke adjustments help
  125. 82 22r water pump
  126. 1981 Yota Pickup Timing Cover
  127. 1983 Creme Toyota Hilux 4x4 5-speed (Slow Build)
  128. Hissing noise from EGR valve?
  129. Pickup brake cable
  130. Old vehicle OIL
  131. 1983 toyota pickup
  132. 22r valves
  133. F/S 22R Smog Parts & More
  134. 83 3rz swap
  135. Weber 32/36 question
  136. Is this truck lifted??
  137. U haul 6bolt read axle
  138. wanting off road bumper for 83 toy
  139. Head Gasket failure after 25,000 miles?
  140. Trunnion bearing/races
  141. Fuel in vacumn lines
  142. Replacing the rear diff on 76'
  143. 83 Hilux 22r NO SPARK ~ PLEASE HELP!!
  144. 82 engine installation questions
  145. 82 motor mounts
  146. 77 smog delete w/ Weber carb
  147. 82 4x4 power steering
  148. Help. 77 pickup gm ignitor swap
  149. 82 4x4 exaust
  150. 82 smog
  151. 20R Vacuum Decal needed
  152. Carburetor guys, Help!
  153. Early 1978 Toyota Pickup (Hilux) GM Conversion Wiring Question
  154. 20R/22R/22RE Timing Cover & Water Pump Bolt Torque Specs
  155. 1st 2wd PU body onto 2nd gen PU 4x4 frame?
  156. 82 r23 piston rings
  157. 82 timing chain
  158. ression test results...Should I be concerned?
  159. 82 4x4 calif pickup electrical
  160. 5 speed tranny. 2wd vs. 4wd?
  161. 2WD bed Vs. 4WD bed...
  162. Optimal compression?
  163. Will a longer slip yoke cause issues on an 83 auto?
  164. What to do with the 81
  165. 1984 22r that is a puzzle for not firing up
  166. 1983 Toyota pickup first generation does not idle until warm.
  167. Front Axle/Hub rebuild question
  168. What are my options for lifting a 1980 2wd Longbed Pickup?
  169. More 79 Pickup AC clues & R12 recharge Q:
  170. 82 4x4 carb and smog
  171. Will turn over, but NO fuel?
  172. If its not the Alternator that's bad...
  173. Where is 79 P/U AC Pressure switch?
  174. Suddenly, no clutch pedal pressure
  175. 22r cutting out or loading up?
  176. Please help me find this strange u joint!
  177. What is this?
  178. 82 4x4 pickup
  179. Charcoal filter/fuel return
  180. Sbc swapping a first gen
  181. Shocks on my 1980
  182. 3rd one! Lol.
  183. Looking for more guidance.
  184. Help! Need New Fuel Pickup
  185. front transfer box / propshaft companion shaft removal on 80 Series Landcruiser
  186. Am I missing something? (HySteer)
  187. Seized engine, is there hope?
  188. Low miles 1980 i just picked up. Thoughts?
  189. 79 Longbed: Any pics of metal/frame behind headlights?
  190. 1979-1983 Toyota pickup original rear fender flares?
  191. Where Do I find stock Cam?
  192. 3.4/5spd in a 82 2wd....
  193. Hub vs. axle seal leak?
  194. Looking for a driver side window
  195. 82" IFS upgrade (brake line q)
  196. Stock drag link needed
  197. My clutch popped
  198. lifting a 77 whats best way
  199. Truck won't idle when warm for 1-2 minutes, then fine
  200. 83 Toyota diesel
  201. 20R Engine Compressor Bracket Mounting
  202. Wired up and charging (charge light still on) really need advi
  203. how do I block the water choke on 20r intake manifold?
  204. 1989 3.0 fuel pressure regulator
  205. Catalytic Converter Install
  206. Hot Engine, White Smoke, Cold Radiator
  207. Gas pedal keep getting stuck
  208. Arb Springs and bumpstops?
  209. 4wd fender instead of 2wd fender?
  210. 1981 came with a L52?
  211. How to Fix Door Locking Mechanism
  212. What head is this?!
  213. Radiator fluid rises when cap off?
  214. 79 20R Exhaust to manifold gasket(?) and release fork clip Q:
  215. Ignitor igniter 1983 toyo truck 22R base
  216. 3 wire alternator question
  217. Alternator swap question
  218. New headlight recomendations
  219. 22R igniter 1.5v test
  220. Bearing #3 relpacement
  221. Neutral safety switch 1981 pickup?
  222. Mechanical Speedo to Electronic?
  223. Rebult my SC 22r motor. not starting
  224. Jason's 1973 Hilux Chinook
  225. '82 2wd 22R Pickup Engine Swap Options?
  226. 1981 Pickup AC
  227. 1980 Build and Rebuild - 3.4 swap
  228. Help Identifying Noise on Deceleration (1982 4x4)
  229. Paint color question
  230. coolant temperature sensor needed? 1983 22r.
  231. GM ignition Conversion question (LX301) for single wire distributor.
  232. L52 swap for an L45 in 82 Hilux 4wd diesel with 2 piece bell housing?!
  233. Fix the '79 or let go?
  234. scored a43d transmission yoke solutions?
  235. Ignition switch
  236. Can I plug this off?
  237. A43D rear seal removal help?
  238. Offenhauser and Weber Carb install help
  239. Turboing a 2.2 Liter Diesel
  240. 78 hilux rwd rear brake line
  241. What are they worth?
  242. Rusty cracked chassis on '83 pickup
  243. 4WD 22R Oil Pan / Oil Pickup Tube Question
  244. Compression Test Results. What Do You Think?
  245. Swapping from Weber back to stock carb
  246. Stock 22r distributor vs D.U.I. hei
  247. Early 1978 Toyota Pickup Flasher Location?
  248. 1979 R20 Overheats/L43 Trans goes South
  249. Early 22r performance heads
  250. Wipers not working
