PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25
  1. about to get my first 1980 pickup
  2. 81' steering problem
  3. 1982 toyota trans problems HELP!
  4. Do stock FJ40 steelies fit our trucks?
  5. Leaf springs...are these good?
  6. Carb screw settings
  7. Famous EGR elimination. However doesn't wanna stay running.
  8. Oil In Carb & Breather Assembly
  9. Several problems, would appriciate some legit help.
  10. Posi, limited, or open?
  11. replace
  12. ran into a snag!
  13. Carb woes
  14. Lift question
  15. 22r weight?
  16. 3" body lift ?
  17. mild carb troubles!
  18. Steering Gear Box
  19. what needs to be extended?
  20. Crankshaft resistance -- 22R
  21. 83 wont start
  22. Another lift question
  23. What's my 1-owner, 1980, 4x4 pickup worth?
  24. Heater control valve
  25. backfire'n carb
  26. Front Drive Shaft
  27. online 79-83 service manual (sort of)
  28. Bumper Compatibility
  29. Aftermarket OE Replacement fenders
  30. Bed replacements?
  31. Good Swap for an '82 toy 4x4
  32. fire breathing carb?
  33. winch bumper
  34. weber carb
  35. New 83 pickup
  36. Need some help welding
  37. how much lift?
  38. Best place for new springs?
  39. Worst oil leak EVAR
  40. Welding my 83 front and rear
  41. I guess I'm a newbie
  42. efi swap questions
  43. new bumper?
  44. 22r swap in a 79
  45. Clutch Options
  46. Dash electrical
  47. 83 steering problem
  48. Clutch
  49. Trail rig
  50. seat swap
  51. More Power
  52. 71 Hilux Stereo Install HELP!
  53. Help: 1983 22r pickup w/ rough idle & more
  54. 82' really bad gas mileage
  55. just got my 3rd yota pickup!!
  56. First Toyota on Saturday, a Few ?
  57. Driveline removal
  58. NEW to FORUM and YOTAswith a question
  59. What wheels will fit our trucks?
  60. swapping out yoke
  61. overcooling, now overheating?
  62. Spring options.
  63. 1982 Shifter question
  64. 83 trans into a 80 4x4
  65. AAL's and a new bumper
  66. Engine Replacement Questions
  67. leaking oil from head on 20r
  68. Transmission upgrade 1980 4x4
  69. its begun....
  70. towing capacity
  71. 80 2wd gas mileage ???
  72. Differential Pinon Nut
  73. got the cab painted
  74. Carburetor rebuild questions
  75. Seatbelts
  76. MSD Ignition ( PN6200) for my 22r
  77. histeer power steering for a 1979
  78. Me, my dog, and a 77 sr5
  79. rear bumper ideas
  80. 32/36 dieseling when shut off
  81. Swapping gears on my front end
  82. Selling the '80
  83. good flexx
  84. crossing water
  85. Wheel cylinder help
  86. Bumper Ideas for my Trekker
  87. humming/ vibration coming form the rear end
  88. hard to shift?
  89. Gear To Tires Size
  90. L52 to W56 swap
  91. Figuring Mileage and odometer readings
  92. DEATH wobble
  93. IFS Rear springs?
  94. rear shackles
  95. No offens to the 4runner owners
  96. 83 Yota Upgrade Help
  97. Problems removing shifter
  98. Good deal or not?
  99. Who DDs There First Gen?
  100. normal warmup time?
  101. Hilux 4dr
  102. 1979 with AC?
  103. Part out? Or sell?
  104. I'm new and needs some help please
  105. Voltage Ragulator ??
  106. Ebay finds thread.
  107. Looking for a cheap clutch
  108. Front End Sheet Metal Interchange
  109. 1981 Toyota Truck Wiring Diagram
  110. What is the blank plug next to cig lighter for?
  111. holly troubles
  112. Speedo
  113. Vibration
  114. New guys thread
  115. 22R temp & oil sensor vs. 22RE sensors....?
  116. Head Gasket job made easy?
  117. Herculiner
  118. Brake line help....
  119. Lifting with just blocks
  120. Unique Exhaust
  121. alternator tested good..now what
  122. alternator has fear of water
  123. What makes a truck an SR5?
  124. Alternator
  125. wiper arms...
  126. heater/blower controls
  127. pictures of the newb's ride
  128. repainting grille and headlight surrounds
  129. lift kits, are they equal?
  130. Timing chain difficulty
  131. gear oil change
  132. 83 yota
  133. Emblems.
  134. Part Numbers
  135. Women who drive first Gens? or even second gens?
  136. Removing carpet stuff?
  137. Clutch Question
  138. head gasket
  139. Question on light bars and brush/bumper guards
  140. timing chain adjuster
  141. What transmission for '83 5spd 4x4?
  142. oil not circulating?
  143. 1981 Toyota factory Service Manual on ebay
  144. Girlfriend hates it but i wanted to know what other people think of it.
  145. e with smog - running rich?
  146. Exhaust Diameter
  147. Tranny & Engine
  148. Axle Wrap
  149. Shocks
  150. Carburetor problem
  151. 1976 Toyota Sr 5 pick up For Sale
  152. advantages/disadvantages of removing smog
  153. Transmission Fluid Change
  154. I'm pulling the engine
  155. mysterious substance
  156. Opinions on Weber carb? 32/34 or 38mm?
  157. driveshafts
  158. Looking to get new wheels/tires. Need help
  159. Rebuild time
  160. brake problems
  161. How hard to find?
  162. 82 troubles still
  163. new to forum; my build
  164. Factory Stripes
  165. Radiator flush question
  166. Weber Carb Rebuild
  167. 1981 toyo pick Up 22r fuel issue
  168. vac. problems
  169. V6 front calipers on 83 solid axle
  170. the invisible part. help?
  171. 81 Pickup Worth it?
  172. wanted1981,4x4L/bed frame
  173. synthetics worth it?
  174. 20R/22R Hybrid
  175. thought this might be of interest to someone here
  176. 1983 on Ebay: 33K Original miles
  177. Faulty Fuel Level Sending Unit?
  178. OEM clutch
  179. '76 20R spark problem
  180. front end rebuilding questions
  181. Cheap/Easy mods?
  182. fuse box
  183. Water in Gas?
  184. Any suggestions?
  185. Gas Mileage... not so good...
  186. stripped spark plug
  187. new member, wierd problem
  188. new to toyota's
  189. gearing up
  190. Weber 32/36 jetting?
  191. '80 pickup HARD to turn
  192. carb lean out?
  193. Overheating Engine????
  194. Carb gremlins
  195. why is my suspension so bouncy?
  196. some pics of my '82
  197. missing vacuum line plz help
  198. 82 pick up
  199. The Rebel.....
  200. speedometer cable
  201. Newbie with a few questions
  202. What did he break on my truck????
  203. new guy
  204. stalling for years now
  205. found another 1st gen!
  206. problem with 22r
  207. more power!?!
  208. 20r 22r?
  209. How often do you see Trekkers?
  210. 1975 Hilux with 67,000 miles and 20R. $750!?
  211. Charging System Advice- Has anyone seen this?
  212. Ignition Tumbler
  213. thinking about a pre 84
  214. Whats is worth?? 82 Short Bed
  215. Craigslist Lift
  216. diagnosing!
  217. somethings fried
  218. hub assembly
  219. just finished my 81...dont drool
  220. toyotas for sale
  221. powersteering
  222. hysteer questions
  223. power steering swap
  224. Need help with my yota!
  225. Adding A/C to a 79?
  226. Weber Carbs
  227. I need to prioritize, and i need some help.
  228. Stock Dual Battery Trays
  229. Projector Headlights?
  230. a trade
  231. is it worth it?
  232. connecting rod question
  233. weber tuning
  234. The Yellow beast!!
  235. What happend!
  236. Any Suggestions!!!!
  237. What transmission is this?
  238. Time for a chassis build..
  239. wont start back fires out carb and exhaust
  240. starting it for 1st time in ten years
  241. the day the music died
  242. Inside Width Of Bed
  243. 82 Toyota Factory Service manual
  244. 22R/22RE GM alternator bracket
  245. need good direction with carb and vacuum lines
  246. 82 Truck No Start
  247. Few questions.
  248. 1982 pickup 2wd L52 5 speed
  249. Lincoln Locked
  250. tranny swap on 1980 4x4 P/U
