PDA
View Full Version : Pre 84 Trucks
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 82 pickup steering column swap
  2. 1971 HiLux fuel tank
  3. 1979 Toyota 4x4 headlight problem
  4. 20R Exhaust Runners?
  5. Help Identifying 5spd Transmission
  6. Cup holder 1983 Toyota Pick Up Bench seat
  7. What Have I Done....
  8. Value for a 1983 Toy Trailblazer
  9. 1980 Toyota Chinook Resurrection
  10. Coolant in oil?! What to do, what to do.
  11. Radio/Speaker Wiring Butchered(HELP)
  12. Swapping 22r alternator to an internally regulated one
  13. 1980 Pickup Ignition Issue
  14. Charge/Sensor Lights - 81 Pickup
  15. 82 Frame patch. What gauge?
  16. questionable 1978 chinook won't pump gas/can't fill tank
  17. Carburetor Heat Spacer Help - 1981 Toyota 22R
  18. Cab mount supports in 82 4X4. How to fix?
  19. Smog crap
  20. 1983 Toyota Longbed - Need a bed mat
  21. Radio for 81 pickup
  22. A few body repair/other questions on 82 pickup.
  23. 1982 Toyota quit on me
  24. L52 transmission
  25. 1982 Fuel Pump Relay Location?
  26. Stuck Sleeve
  27. 1983 22r Rich & Rough
  28. Power Steering
  29. Possible stuck open Cold Start Injector
  30. Carburetor dumping fuel at idle
  31. Looking ForCarburetor Knowledge
  32. 1981 Diesel 2WD pickup “runaway”
  33. Tacometer wiring 1977 pickup
  34. Tires
  35. Blower Motor
  36. Smog a weber
  37. Battery replacement nightmare
  38. Let me see your later model Toyota wheels!
  39. Misc Parts
  40. 1982 toyota motor home 22r vs pickup 22r
  41. 1983 22r Knock Sensor
  42. 72-78 Toyota Pickup Replacement Fuse Cover
  43. 79 - Replace or repair AC Evaporator Core?
  44. Fuel Tank for a 1982
  45. 1981 sr5
  46. Transfercase output bearing
  47. hackjob wiring
  48. 1980 20R Idle Issues
  49. 79' toyota pickup with the 20r flooding
  50. Issue with locking hub
  51. Cab weight?
  52. 1972-1978 Front Parking Brake-NEW-Found
  53. Where to get lower shift boot for manual?
  54. Wiring issues Please help!
  55. Transfer Switch (4wd indicator) Replacement 79-83
  56. wideband O sensor install in original bung on 1983 22R carbureted
  57. Is There a Drop In For 4runner - Have 2.4L Diesel
  58. 82 PU Lift
  59. Looking for side window defroster parts for 1980 Toyota Pickup
  60. New Toy
  61. Suggestions for early pickup build
  62. Questions on lowering 4WD 82
  63. Ebay headliners...
  64. wiper motor question
  65. 1981 4X4 gas tank.
  66. Tach working intermittently...
  67. Starter/ignition wiring help
  68. Starter/ignition wiring help
  69. Suspension lift question
  70. Transfer Case Bearing?
  71. 81 Toyota diesel 5 speed par search
  72. L42 transmission help
  73. Need technical help for a late transmission swap into a 1977 Hilux no
  74. 18R Weber 32/36 idle issues
  75. Help Identifying Dual Carb Setup from 20R
  76. 1982 Toyota Hilux Diesel 2.2 original or not?
  77. Tilt steering column for 82 4WD pickup
  78. Air flap wont close
  79. Finally doing bodywork on the 82 pickup
  80. L52 trans to sbc bolt pattern
  81. Tranny swap
  82. Free Toyota 1981, 4x4, but . . .
  83. ‘83 4WD pickup Charging Woes
  84. 1981 Build For Kiddo
  85. GM upgrade Alternator 1981 22R
  86. 1982 22R issues - idle/stutter, brake light
  87. 81' 4wd headlight door fitment
  88. What Is Going on?
  89. 1980 4x4 pickup choke control relay location
  90. 1982 Toyota Pickup dies once it reaches half tank
  91. LN46 Hilux project
  92. '83 22R PCV to Carb Question
  93. Having issues with ignition. 78 20r pickup
  94. Make shift tailgate latch suggestions (82 PU)
  95. 1983 wiring loose-ends
  96. SR5 Top dash vents
  97. Having ignition issues 20r
  98. 82-22R-Holley Super Sniper Installed
  99. 1973 Hilux 2wd body swap to 1980 4wd frame?
  100. How many links on a timing chain ....
  101. Are 86-88 4runner grilles interchangeable with 1983
  102. Source for Molded Full Carpet for 75-83 Pickups & More Year Models
  103. Vacuum advance replacements?
  104. Interior parts for 79-83 pickups
  105. 1978 Horn
  106. Power steering pump fitting
  107. New aftermarket coil ignitors ebay less than $30
  108. 1982 Project woes
  109. 1980 Toyota Pickup Tach Issues
  110. help identifying growling noise after g52 swap!
  111. Will this 4wd lift work with 2wd lift?
  112. Diagnosis help on 1980 hilux?
  113. trans. fluid leaking out shifter hole
  114. 1982 22r blowing black smoke and running rough
  115. How hot should front discs/hubs get?
  116. Rebuild problems
  117. Throw out bearing squeak?
  118. 1981 SR5 with a "D" in the VIN #
  119. 81 Voltage regulator replacement
  120. SR5 1982 Pickup won't start with new ignition switch.
  121. 1982 Toyota pick up/1999 Tacoma build
  122. 1982 toyota 4x4 pickup project.
  123. 83 4x4 g52 swap help with drive shaft lengths
  124. Excessive Backlash on Rebuilt Differential - where'd I go wrong?
  125. Wheel bearing and header replacement costs
  126. 1977 speed sensor swap
  127. 83 Wiper Motor
  128. 82 2wd Sr5 lower cluster
  129. 82 fuel pump output too low?
  130. Are the dimensions of crossmembers for 4 Runners and Pickups Different?
  131. 1979 Hilux Combo switch replacement
  132. 82 pickup sprayers not wired
  133. Trouble with my 79/83 20/22r hybrid
  134. Engine work costs
  135. 1979 Hilux Combo switch replacement
  136. Damaged Front Brake Line. Where to Find Suitable Replacement?
  137. 82 pickup defrost vents
  138. 1980 truck upgrade suggestions
  139. Strange ignitor wiring.
  140. Timing chain, do i need a head gasket also?
  141. Steering Column Cover
  142. Calling all yota pros and 20r/22r users/builders!
  143. Headgasket/rebuild questions
  144. 83 Toyota parts
  145. Door Panels
  146. help can i do this swap 82 22re with a 87 22r? both carbed
  147. Installing new distributor timing mark
  148. 1983 22r Mojave, crank but no start issue
  149. Looking for idle mixture screw for 22R Carb #35090
  150. Mechanical fuel pump arm broke and spring is in the engine
  151. 1981 Trekker needs simple A/C help!
  152. 82 carb troubles.
  153. 1982 4x4 new purchase and refresh
  154. 1975 Toyota Pick Up Leaf Spring Compatibility
  155. Support bed by the hooks?
  156. Please help me with the carburetor! I can't breathe from the stench!
  157. LN46 L 2.2L diesel Power steering help
  158. What is port called?
  159. Bit off more then I can chew.
  160. 82 Toyota Pickup Tail Light Relay & Other Questions
  161. GM 3 wire Alternator wiring
  162. Timing Chain Guide Bolt Size
  163. 82 Toyota Pickup climate blower and dash lights
  164. 1979 Toyota Pickup Radio Bezel WANTED!
  165. Removing Front Fenders 82 2wd
  166. 1976 SR5, No Spark when Cranking
  167. 1st Gen replacement seats
  168. Bad fit of replacement parts
  169. Distributor Pickup Sensor Info
  170. Refitting 79 oil pan
  171. Hilux California
  172. 1982 pickup windshield washer nozzles.
  173. L52 Transmission Transfer Adapter Bearing
  174. AISAN Carb Flooding AFTER Shutdown
  175. What Power Steering pump do I actually have?!
  176. 1982 22r Running Hot (88k Original Miles)
  177. 82 pickup bigger steering wheel?
  178. Seats for a 82 pickup
  179. EGR to PCV 20r Weber Swap
  180. Help to figure out vibration and noise in rear end area
  181. What is this?
  182. 1976 20R flooding out when warmed up but runs fine when cold?
  183. Winch bumper mounting options?
  184. 1983 Pickup Restoration
  185. 4Runner seats
  186. 83 4x4 Fuel Pump
  187. Temp gauge wiring
  188. Need help with my 1982 idle
  189. 1981 22r Toyota pickup won’t start after running
  190. $3k vs $5K paint job
  191. 1982 - Power steering fluid on top of reservoir
  192. 1972 - 1978 Pickup Replacement FLOOR PANS
  193. Can someone tell me what this thing is above my electric fuel pump? 1976 20R
  194. Anyone Know What Calipers / Rotors These Are? IFS Hubs?
  195. prop shaft dust cap covers?
  196. 83 Toyota SR5 - L52 Transmission broke
  197. Setting timing after removing the mechanical fuel pump on a 20r
  198. Want to share this cool find. 1983 Sales brochure
  199. 1977 toyota pickup axle nut lock ring
  200. Mystery Bolt…
  201. 1983 Audio upgrade - Retrosound
  202. 2wd 1983 Toyota pickup sr5 oil capacity
  203. 22re cylinder head
  204. 1975-1978 Pickup Fuel Pump Check Valve Replacement
  205. 18rc to 22r swap on 1974 Chinook questions
  206. looking for a quality 20r Head Gasket
  207. 1983 Pickup seat covers
  208. 1983 Toyota Trauck - Brake light and batter light on
  209. Clicking noise when steering at a stop (1980 Pickup)
  210. Help removing SR5 radio bezel
  211. 81 front end help needed
  212. 1983 pickup electrical
  213. 1983 pickup electrical
  214. 1980 toyota pickup won't idle when warm
  215. Introduction/Build
  216. Will my 1983 ever pass emissions test with no smog pump??
  217. Conversion
  218. Strong gas odor
  219. Manual trans to auto swap question
  220. Do I need to repaint my 83?
  221. Voltage Drop with GM 3 Wire
  222. Engine spec/boosted questions
  223. squeeeky brakes? basic // 82 2wd
  224. 1983 Smog Pump?
  225. '80 Pickup LSPV Replacement
  226. Need help lifting a 1977
  227. Question 1981 Toyota SR5
  228. Trim nuts?
  229. No electrical power to anything
  230. Anyone know if these wheels fit without spacers?
  231. Fuel cut solenoid o-ring size?
  232. GM HEI Ignition
  233. 1982 4x4 pickup rear wheel cylinder removal
  234. 1983 4X4 bolt size
  235. New member with my '83 Creme/Terracotta puff and a story
  236. 20R engine rebuilt help.
  237. 20R engine rebuilt help.
  238. 20r with coolant hole and weber
  239. 83 SR5 Black Tailgate decals
  240. Tailgate Decals
  241. MS 151 T C-E chainsaw
  242. 22r bogging
  243. Horn Plunger Replaced
  244. 78 hilux Radiator replacement
  245. Voltage regulator
  246. Top of Piston hitting cylinder head
  247. 83 Pickup -Can't lower Idle
  248. 1980 pickup SoCal Help!
  249. ‘82 Pickup 2wd won’t idle without giving it gas
  250. '81 SR5 Instrument Cluster Refurbish Service?
