PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Where can I get these emission hoses?
  2. Fan clutch not engaging
  3. Consequences of disconnecting O2 sensor on '82 carbureted pickup?
  4. very bad tire wear
  5. Weber 32/36 and timing.
  6. Tow Hitch Question
  7. Stock shock mount HELP
  8. can you identify this?
  9. Dies at idle
  10. Parts availability for pre-84 trucks
  11. Doetsch shocks fittment issue
  12. Finding rear window glass Seals/felts??? '82pu
  13. Oem SR5 wheels
  14. Unexpected surprise - 21R Fuel Pump/Parts Compatibility
  15. 1983 w/ 20r distributor amd desmogg
  16. 78 Pickup wiper arms
  17. 81 sr5 22r no power in 4th and 5th gear?
  18. DIY Straightening Frame, any ideas?
  19. So I weighed my truck today...
  20. 1983 sr5 cost of front knuckle rebuild?
  21. 1983 sr5 heater not heating
  22. '82 Sr5 Hood stripes
  23. Chevy tbi 350 swaps 79-83 ONLY
  24. 22R Oil Leak Help
  25. Front axle - axle shaft installation issue
  26. 1980 p/u htr valve
  27. after market radio placement
  28. 1982 shifter rebuild
  29. 1983 Dash swap?
  30. rear exhaust fitment
  31. Cold starting issue
  32. 1981 Toyota Hilux 5 speed conversion
  33. Tracking down oil leaks
  34. Trans-Dapt 2181
  35. Stock 1982 4x4 truck rim size?
  36. 2wd verses 4wd oil pan and pickup tube
  37. 1983 SR5 A/C belt making loud noise.
  38. 1980 tune up, or remedy for a rough idle
  39. Engine lag on acceleration 1980 20r
  40. 83' Pickup Fuel Tank Replacement
  41. hilux mk1 parts
  42. GM alternator instal and now no spark
  43. Dual battery / radiator overflow & wiper fluid tanks
  44. 1980 rear disc brakes
  45. Dies at idle
  46. New to the yota
  47. '82 pickup, wiper issues
  48. Ugh HELP. No headlights/brakelights 1979 4x4 pickup.
  49. Need a vacuum diagram! also mystery hose
  50. 1983 4x4 inside of cab getting to warm
  51. Putting a winch on a 1982... How to? (Ideas Plz)
  52. Camper Shell Lock
  53. 1980 Toyota getting Fuel in Oil
  54. Distributor has no vacuum advance diaphram
  55. 73 Hilux EWD?
  56. toyota tacoma front bumper on a 1981
  57. Part (Number) Needed
  58. Carb Jets?
  59. Lowering an 81 4x4
  60. front driveshaft slip yoke question
  61. 79-83 4wd Rear Mud Flap Brackets
  62. Stock Carb Losing Fuel After Sitting
  63. bent tranny tunnel.
  64. 83 pickup won't start after taking carb out and putting back in
  65. Vent shades, wind deflectors, windows
  66. 83 22R Bucking Like a Bull need help..
  67. What gears???
  68. Extremely high oil pressure!
  69. Control arm bushings on a 78 2wd??
  70. 22r Carb Float Level too High.. What happens?
  71. 1980 Heater Problems plumbing help
  72. 22R Running Rough at low RPM's
  73. late model trans in my first gen
  74. Truck overheating and...
  75. AC compressor help
  76. Please help!!! 81 2WD with possible rear end issues
  77. 1980 sr5 instrument cluster wires
  78. Spits sputters and back fires
  79. Stock am fm radio how to
  80. 1983 toy
  81. Price for a 1979 mk1 toyota hilux.
  82. post pics of your custom built shock towers FR/RR
  83. Tires, gears, RPMs and Speedos, road speeds and GPS + calculators– Geezus really ???
  84. Anyone know anything about pre-79 trucks?
  85. Running rich as hell.
  86. dash reconstruction
  87. 32/36 Weber or 38?
  88. Oh no...t-case output is loose!!!
  89. Weak HVAC blower? Thoughts?
  90. At my wits end with this truck
  91. 83 toyota bed removal
  92. Advice for making a custom dash in 81 toyota
  93. 83 Blowby and Timing Jumps Around
  94. 1982 Toyota 22r (Carb) won't start
  95. Value this 1980 for me
  96. solddammit!!!!
  97. Re-gearing a 78 rear diff
  98. 1980 pickup front end vibration
  99. New fuel pump... no fuel
  100. Sheet Metal
  101. is it high in the back or low in the front
  102. Fan shroud label...
  103. Long Beach Bed Manufacturing
  104. 80 4x4 tough getting into gear
  105. transmission
  106. where can I find 1983 Toyota rear spring bump stops?
  107. Weber conversion help
  108. stock suspension sit level?
  109. Question about a 1981 front grill and lights
  110. Any tricks for restoring toyota badges?
  111. 1980 pickup carb issues? Possible swap?
  112. 1982 22R emissions issues...Colorado...High CO
  113. 82 toyota keeps stalling
  114. L52 tranny in a 81
  115. 1981 relay rod
  116. 1981 Toyota Hilux Leaf Springs
  117. Trailer Wiring Problem
  118. Inner fender question
  119. Trail damage, suspension help
  120. simple propane convertion for 22r
  121. distrbutor drive gear removal
  122. help finding restoration type parts for truck
  123. fender emblem removal help
  124. Malfunctioning gas gauge/Blinkers 78 toyota
  125. 83' solid axle steering knuckle question..
  126. First post and needing advice on a complete re-wire
  127. stock carb jet sizes
  128. Old man emu rear springs
  129. Door Window Glass Install
  130. 22r weber 32/36 hard starting when hot
  131. lacking power and acting like out of fuel
  132. Part Truck on CL
  133. Black Smoke
  134. Back glass removal
  135. '83 Alternator wiring hack
  136. Idle stop solenoid source
  137. Sudden zero compression on cylinder number 3
  138. 83 yota 3in rough country lift need shackle help!!
  139. How much is a 83 sr5 long bed 4x4 worth?
  140. Wipers won't seat when off
  141. pwer steering box rebuild kit
  142. Strange vibration at 20-25 mph in any gear.
  143. My frame is full of sand?!
  144. Newb Question…what is this??
  145. 83 Toyota Dolphin Motorhome: Axle
  146. Help remove my shifter!!
  147. '81 2wd body to 4x4 chassis
  148. efi ignition wiring help
  149. Stubborn toyota doenst like to start or idle
  150. 1981 California AC install
  151. Igniter failure
  152. 81 SR5 transmission help
  153. weber running rich vac leak with spiral adapter
  154. When turning key off voltage drops slowly and engine keeps on running
  155. Wheel and spacer question
  156. 82 Dual Case Conversion
  157. Thoughts on this '82?
  158. Transmission Removal, Need Advice (22r / L50 4x4)
  159. Left heater hose routing
  160. Need help trouble shooting weber 32/36 22r
  161. Tachometer trouble, how to test?
  162. Stock Leaf Springs
  163. 1979 Toyota Pickup Stalling Issue
  164. Transmission noise - clicks when I let off the gas.
  165. 82 Front Suspension Swap, Troubles, Solutions, Lessons Learned Etc...
  166. loose shifter help
  167. 79-83 ECU fix
  168. Starter for 1980 RN37
  169. Pinion and axle seal leaks
  170. Rear Axle Question
  171. first gen lift question
  172. Any Oahu Guys????
  173. a.c. control lights went out
  174. 82 pickup 4x4 missing under load
  175. 82 oil on tailgate can't figure it out
  176. Grinding offroad
  177. 79 PU starting problems when cooling down
  178. 1982 toyota alternator
  179. Clutch adjustment
  180. 1981 Carb Air/Fuel Mixture Screw ?
  181. Help with Weber carb swap
  182. 1979 Toyota charging problems, gettin pissed
  183. Tell me everything you know about this Yota
  184. Pre 79 Bed on an 83 4WD
  185. Why expensive lockers in the front end???
  186. Parking brake cable snapped
  187. Stalling issue
  188. front brake replacement 79 toyota
  189. Gas pipe into tank
  190. Aftermarket stereo panel?
  191. BAT True Body Off: Restored 1980 Toyota 4×4 Pick-Up
  192. Hood coming apart ?
  193. darn truck runnin at 17 volts
  194. radio help
  195. Best OEM Website??
  196. Weber Air Filter
  197. Bucket seat covers
  198. 81 wont start without priming carb
  199. L45 4 Speed no REVERSE!
  200. More Electrical problems
  201. wiring help
  202. 2wd hood on a 4wd
  203. Transmission swap!? 82 swap out w/87
  204. Bomb Proof 22r Motor Mounts
  205. 1981 toy tranny making noise
  206. Choices Choices! What engine to get?
  207. Suspension question
  208. 1979-1983 Toyota Pickup Wheel Pics
  209. just picked up a 1980 toyota breaker breaker
  210. Weber install question
  211. Garage Art.....
  212. Questions about 1980 Long Bed Pickup?
  213. Straight line struggles
  214. Research
  215. 20r weber help
  216. weber 32/36 help
  217. Ride Height
  218. 22r ticks and backfires
  219. Changing cabs
  220. 22R Water Pump Question
  221. FJ40 hubcaps
  222. 3' suspension lift
  223. Cab swapping questions! Help please.
  224. 22r swap with 3.4
  225. Sticky Throttle
  226. 82 22r fuel cut solenoid...seeking advice
  227. 82 SR5 Heater not functioning
  228. new 20r need advice
  229. 82 SR5 Tachometer intermittently functioning!!!
  230. 81 pickup wiper help
  231. Unknown part
  232. Goodyear Duratrac
  233. Upgraded fuel lines?
  234. weber with a sync link
  235. Seats for an 82 (Trekker)
  236. 81 bumper hardware?
  237. I think I have a choking problem
  238. weber carb on 20r what jets?????
  239. Ignition and key cylinders?
  240. timing and tuning the elusive weber
  241. 2.25" or 2.5" exhaust
  242. 1983 4wd restoration
  243. 1982 Windshield Cowl Repair
  244. 1980 restored Pickup
  245. 1983 22r bogging and surging
  246. 81 breaker breaker
  247. GM 3 wire alternator on 1980
  248. I have a theory (white smoke)
  249. 1980 20/22r to "gasp" a 3.0?
  250. SR5 Gauge Pod Alternate Gauges
