View Full Version : Pre 84 Trucks
- links and full width build....
- carburetor rebuild 1983 22r
- need help
- 82 Toyota carb mounting gasket
- My 81 front axle has issues.. HELP!
- Can't get the clutch slave back on
- Lift debate... what should I do?
- 1980 20r fuel pressure question
- A few problems
- Tell me if this trip is a bad idea
- Two yotas, one has to go..... please help :(
- blown fuse and heater issues
- Welded my rear Diff (pics)
- What years will interchange with my 79 4x4 S/B parts?
- should i swap a 99' chevy v-6 vortex into my 83?
- 82 Toyota Carb issuie
- Another random Weber encounter...
- 1981 engine swap question.
- Is this the EGR valve?
- brakes lock up while driving (83, 5spd)
- 20r daily driver?
- what color would you say my truck is?
- cigarette ligher + power
- Fuel pump PSI?
- Fuel filter location on a 1979 4WD pickup?
- adding power steering to a non power steering truck
- Testing you underhood gurus.....pic inside.
- shift boot
- no spark??? 1983 22r
- 1981 FSM for sale on Marlin
- Ran some seafoam in the carb.
- intermitantant wiper relay
- 82-83 sr5 gauge upgrage
- Front drive line problem
- 86 dash and seat into 80
- master rebuild kit for a 22r recommendations?
- Rattle, rattle!
- need help with fuel lines!!!
- Chevys leaf sping swap
- new 83 have a few ?s
- 1st Gen Taxi In Haiti
- Anybody actually done the square to round headlight conversion?
- hi steer question
- So I changed the diff and TC oil, question.
- shifter question
- New Clutch Q's
- I hate people! / Nice 1st gen
- Does this picture of the front suspension look normal? ('79 4WD)
- What brand of roll bar is this?
- Think I need a new clutch?
- Broken Detroits!!!=(
- quick ? about lunchbox locker
- This is what I was talking about
- Driveline qouestion please.
- 302 conversion!!!
- Advice on swapping used 22r
- new 83
- 20R rebuild blues
- Problems with my 81 22r 4x4
- 21R Engine Question
- 1979 Pickup 20R to '87 22RE
- I want it
- Offroading Precautionary Steps!!
- Ok one more try: please help id carb
- Calif. Catalyst E.G.T. Sensor
- Crank bolt!!
- Camper shell Help?
- OEM oil filter or pure one?
- 5 seconds of cranking to start when cold.
- I just got a '82 pickup
- 1983 ghost idle issues (and pic of my truck)
- Quick question
- 1980 Manual Transmission
- brakes
- Need help with engine removal
- HighSteer
- truck not pumping fuel
- 20r ?'s
- clutch problem
- How to change top end speed?
- Price for an exhaust system. Good deal?
- Shifter seat bushing replacement on my 83'
- 83 4x4 manual hub need help!
- dropzone's notebook of ideas, links, mods, misc BS
- Blow by 20R
- Knuckle Rebuild
- Tire chains and lockers
- So y'all call that cam bad?
- Marlin Shifter seat/bushing doesn't seem to fit.
- am i getting a good deal on a 83?
- Wagoneer Springs (front)
- new problem
- The 82 had to take some abuse tonight!
- l45 tranny on 22re block
- My New 83 SR5: Funny Carb Problem
- 81 distributor vacuume question
- Tacomca seats in 82 yota ?
- '85 to Pre 84' Part Swap?
- Front suspension lift, need help
- toyota online repair manual
- Engine Rings
- 3 inch lift question
- making my 82 survive
- Front cardan joint Clicks on my 1980 4x4
- are my gears messed up?
- woohoo! I'm keepin it! but,
- rear leafs up front
- 20R hybrid
- electrical system madness
- 79-80 carburator
- 20r and 22r same timing chain ?
- wheel stud replacement?
- 1983 toyota, got a weber and steering question, see if you know more than i do
- Oil for my 20R
- 1983 Toyota Bed Parts
- Unusual rattling sound from rear- 1983
- What should I do?
- Amsoil in old engine...
- belt drive 22r
- high output alternator
- Transmission identification
- starting my 83 2rz swap
- fill plug
- First tiime wheeling my 83'
- Header for a 83 truck
- I hate to do it!!
- Quick tune up question.
- Day of bad luck.....
- Leaky cab question
- I need some help
- Hot on Craigslist!
- Camper shell
- Questions about options on a 1979 4x4; and a few other questions
- 1980 pickup smog issue
- 1983 Center console
- Cal-smog
- Did some rust/paint work on my 82 *PICS*
- Bucket Seats
- Front drive shaft problem!!!
- 1976 Hilux
- My 1983 SR5 Shortbed
- Running, finally.
- Where can i get a 82 pickup bed?
- whats the difference of a solid axle
- Thinking of Buying a 1982 SR5 4cyl. Have questions
- problems with my '74 hilux carborator
- 1980 Hilux 4x4
- Sas
- My toy mostly done
- leaf spring?
- Trekker delima ?
- 81 toyota- Really Fast signals
- SR5 Gauge Swap
- Getting my 80 today!
- installing gears in the pnw...
- headlight and driveshaft questions
- 20R Low Compression + New Cam
- Exhaust manifold
- 5 speed?
- Blew a headgasket
- Charging problem
- Lexan Windshield
- Engine upgrade
- 5VZ-FE swap
- custom front bumper
- 76 won't start
- Mechanical fuel pump leak
- Weber 32/36 install
- LockRight installation
- Who's Running Emissions Equip. & Who's Not?
- Adjusting the carb
- Where does the vacuum hose connect?
- '79 Toyota transmission.
- Mounting IFS steering box in my 1983
- 81 toyota pickup/85 pickup
- Stuck In 4 Low
- 80 2wd "tailight control relay" location?
- 19'83 4x4 pickup shakes between 45 and 55mph
- Rebuild 20R or Install 22R
- Reverse rear shackle angle????
- what clutch?
- Wont role
- Chassis lube spots.
- A few problems.
- timing chain tensioner
- Chooseing what to buy imput asked for.
- truck doing something weird after turning it off
- Another cold weather problem
- Leaking clutch, need some quick help
- Timing questions
- Route Heated Air to Bed
- Ready to buy a 1st. Gen pickup
- Front axled to frame strut rod (?)
- Any interest in '77 4x4s? Mags for Mary fund
- alternators and water pumps
- Opinions on Bed Configuration, please...
- Engine question?
- My new 83' finally on the road
- Hard starting
- 1st gen guys in artic cold, question!
- knocing noise kind of
- knocking noise kind of
- Truck won't turn over?
- Happy Holidays Fellas.
- need heat
- Metalic or Ceramic?
- aoter turn signal issue thread
- 22r carb revs high when hot
- 22r's rule
- flasher relay
- 83 22r wont run
- more electrical.......
- First Gen RC build-Awesome Detail
- blinker problem
- Weber Carbs
- 1980 Best Motor Swap?
- Rear Bumper Questions
- grind/rubbing noise in front when in 4wd
- tranny or clutch?
- Theme song for first gen owners...
- What to look for after thawing antifreeze
- New truck
- 1st Generation 2wd Curb Weight
- I want to make sure its a 81.
- Anyone had clutch lines freeze?
- Trans help
- good price or not
- 83' broke down already.....
- 83 22r low compression
- Compatable Seats for 1st Gen
- brake problem
- truck trade
- need advice about potential purchase...
- Am I getting ripped off?
- shackles for 63" chevies?
- My 83 2tone
- loose timeing chain?
- 83 22r poor idle + lurching please help!
- what do y'all think my truck might be worth?
- body lift
- 7" Skyjacker lift for my '81
- 79 toyota motorhome
- Couple questions
- Bumper, bumper bump!
- 31's on stock rims
- ifs rear end swap??
- WEBER carb ?'s, high pitch noise from top of carb?
- Cleaning EGR
- A couple pics from today
- 74 Hilux - 18R->22R Swap, axle? brakes?
