View Full Version : Pre 84 Trucks
- horn no workie
- Wiring Question
- strange engine combo
- 82 head light assembly swapp
- Starter motor bolts
- Cold Start Noise Revisited
- Alternator and KC lighting
- Caster with Rears up Front
- 1st generation pickup bed questions
- Front Bumper lift?
- 84 5speed
- 83 pickup 4x4 need help.
- Help with smog line nightmare!
- Smog exempt and want to clean up my 22R
- 1981 4x4 Toyota Pickup Advice please!
- Mystery of the disappearing fuel
- 81 yota pickup spring substitutions???
- Cooling Issues
- Mystery slop in the rear drive line???
- Dual cases
- anchor and shackle bolts?
- 83' Front axle trouble...
- 80 4X4 Next mystery 4.88 Rear Diff ????????????
- body lift for my 1980 2wd toyota?
- Hey guys, remember me? xD I need some carb help!
- secondarey adjustments
- $7 for new carpet...nice!
- 80 4x4 Mystery Clunk in drive train
- What headers/exhaust are you runnin?
- 81 2WD Diesel
- MY new Yota
- 5.29
- Aftermarket Tank????
- newbie '83 22r rebuild ?'s
- Power Loss in Cold/ Humidity?
- Rust repair
- Just bought an 81 4x4 got a couple questions
- 83 Sr5, where does this wire go?
- iDLE ISSUE Shes got a cold?
- Need new springs for my 83'
- Advice on what to do?
- 83 Is Legal
- Just picked me up a '81
- questions on a 32/36 weber install
- Needs a few thangs.........
- 20r cam timing question
- 1980 L43 to L52 Swap "Boot" Question??
- window beltstripping
- 1980 Toyota step bars and pipe doors
- Tune up blues
- Cooling issues!
- 80 tranny-clutch-slave Question???
- Convert FED/CANADA emissions and Vac. Lines to CALI. Config?
- 82 4x4 front wheels not engaging
- Looking for L52 shifter only..Ideas????
- steering help!!
- sorry....
- engine popping?
- 4in lift question?????
- 1980 4x4 heater mystery? (help)
- 1980 4.38 r&p??
- chevy alternator ?????
- Plate on back of 22R?
- My 1st gen face lift
- 1st gen brakes and steering problem.
- My 81 Project
- bed swapping
- Simplified wiring for a 20r?
- failing emessions, need advice.
- Brake Fluid Leak in metal brake line
- Re-doing an 81 4X4 Need advice
- pre 84 lockers
- lost bell housing bolts
- 81 Toyota New to me!
- 81 rear slider lock
- show me your valve cover
- 81 Stereo suggestions
- Semiflat bed build up lots of pics
- Shackles
- 81 Pickup power steering
- wheelin in the 82
- reccomended gears
- 77 truck will only go in 4th
- alternator question
- 4" backspacing, too much?
- Big brake questions...
- just bought an '83
- Question about engine date
- CV rear drive shaft
- question
- 22r With A Holley 450 Cfm 4bbl
- sway bar
- Looking for pics
- tail lights
- New Guy
- My 82 is a go-cart now
- Center Bezel Questions
- Weber intake plenum
- How hard is it/ how do I remove the carb on my 79 20R?
- leaky 22r
- 2rz swap in 83 toy tech help!!
- ditching the 20R water choke
- 1981 4x4 dash sensor light
- Frame rust repair
- new tail lights but idk how to wire them
- cooling issues...
- electric fuel pump on my 82'
- 82 pickup radiator question
- why 20r on 22r
- 22r misfire
- tonneau covers?
- V6 Calipers
- 79 vacuum help
- i need pics of wiring under your hood.
- help!!79 4wd w/9mm drive shaft flange holes!!
- new tail lights
- Need help replacing my fan belt!!
- Where to buy rebuilt 22r motor
- Help with post 2rz swap????
- New '79
- 22R tick/knock at idle and decel
- new project: got 2 yotas for $150
- oil pan findings... what is it?
- Has anyone ever broke the crossmember
- Good website for body and motor parts...
- funky cooling temp need help
- Will a 1980 2wd cab bolt to a 1980 4wd frame???
- Final suggestions before I make a purchase..
- 22r Engine Exchange cost
- 1982 2WD Pickup thumping noise & feel when braking
- 32/36 weber installation???
- T-case bearings
- 1981 Toyota 4x4 dash modification
- 1980 4x4 P/U Lift???
- Headlight Dimmer Switch
- Looking for bed swap...
- 20r head replacement options
- 82 SR5 2wd
- transmission wont come out?
- 1978 toyota axles
- removing emissions
- 83 22r low rpm stumble/misfire/surge/cutout/i don't know
- Custom (Homemade) Accessories
- How to get some power from 80 20R
- Beds?
- Ignition Advise?
- 83 width?
- engine is ticking
- 4.37 gears good or bad?
- 82 22r question
- lost my windshield
- stock chrome rear bumper
- transmission losing first gear
- need trans and engine help
- New truck
- What is this thing?
- what tranny is this
- 63in chevys, linked, or 1/4 elip.??????
- 81 emissions
- Stock Ride Height?
- Question About Pre 84 2wd suspension
- alt brakets?
- Manual Brakes - did they exist on pickup?
- Mechanic Needed: Oil leak and Water Pump/Timing Belt Replacement - Hampton Roads, VA
- Bed Question
- Need help - sourcing parts for W50?
- fenders
- Looking for experience with stock carb - idle cut solenoid problem
- What is this shackle thing?
- More intermittent poor running on my '80 (and free parts)
- 83 toyota pick up
- My Banana, 81 yota
- new to toyota's but gettin excited
- 1979-1983 Truck Owners-PA, NJ, MD & DE?
- New 81
- 63" chevy springs question
- dash lights
- Push/Light bar
- Carburetor rebuild
- question on lift with tire size
- 83 ignition module problems.
- New head gasket leaking
- Wheeled the 83 for the first time
- 5inch lift, front drive shaft not long enough
- fuel pump newbie question on 22r
- transfer case id
- New Yota any suggestions?
- 82 clean up/ build/ paint
- 20r backfiring in high gear please help
- One wire alternators
- I'm new here and I hate Vacuum Lines.
- Pressurized ???
- ordered redline weber, few ?'s
- Got the old yota together and back on the road
- PiC request
- daily driving my 83, some questions.
- Fuse block interchange?
- daily driving my 83.
- diy site with part#
- 1981 2wd oil leaking, but from where?
- Photos....
- Fuel leaking out of carb - lots of cranking
- 83 what gears
- 1979 toyota truck r20 model rn28l help
- my 82 DD yota
- Alt wiring
- Got a new truck, scratching my head
- I don't know if this is of interest but...
- air conditioner ....help
- 1982-83 Cruise Control System
- strange foreboding sound from under the hood
- Shifter(s) Thread Sizes?
- 82 short bed that i would like to convert whats on the bed of this truck
- how to start the engine out of the truck
- 22r oil pan
- 1981 - Convert to automatic?
- 22r/20r Hybrid detailed info
- putting a 20r in my 82'
- 2 wd bed
- AC Compressors and AC Parts RESTORE!
- pinion preload?
- Overcarbed??
- Muffler Options
- Odometer question
- 95 4runner third member
- First truck - a mint '82
- engine rebuild kit
- 4wd Wire cant find one
- hey guys
- Rotational squeak after brake job?
- front axle
- bed swap again
- Yolk for U joint
- Power Steering Pump?
- herculining my bed!
- Clinometer: Ideas-Installing to a 1980
- Manual Steering box signs and symptoms
- Fuel pump question
- steering and shock question
- Factory brush guard?
- Clicking Clutch?
- bed swap
- Weird steering issues need help
- front 3rd help
- Swapping in earlier dash?
- Buying a '79 that "needs work"
- Hysteer questions
- Pictures of battery tray on 1981 4x4 ?
- 1982 22R Carburetor Emissions Throttle Positioner troubles
- opinions on companies?
