Pre 84 Trucks 1st gen pickups
transmission wont come out?
Old Sep 25, 2009 | 10:56 AM
truckdude239's Avatar
83 toyota 22r with 4 spped tran mission comes out about 3 inichs and the is it can not get to to come any farther and we are stumped sort of knocking a hole int he bellhouseing and unbolting the clutch disc i dont know what to do
Old Sep 25, 2009 | 01:27 PM
83's Avatar
83
Umm...huh?
You're pulling the tranny? You don't mean won't come out of gear? If the d-shafts are all removed, wires unplugged, shifters removed, and all bolts removed, it should come out just fine. Brain is a little tired so forgive me...but does the slave cylinder bolt to the bellhousing or engine? That could hold things up. Anyways it's hard to say from this end, because we don't know if you've got everything removed.
Somebody put a 4 speed in your truck, eh?
Old Sep 25, 2009 | 04:21 PM
It is an 83 so normal 4 speed we got it out tonight had to cut a hole in the bell houseing and unbolt the clutch the polit bearing was stuck on the end of the shaft
Old Sep 25, 2009 | 04:37 PM
85excab's Avatar
yep, the pilot bearing does that sumtimes, just gotta pull harder.
Old Sep 25, 2009 | 04:56 PM
Plumbrbob's Avatar
is the tranny in gear still? putting it in nuetral helps sometimes.....
Old Sep 25, 2009 | 05:12 PM
We had another truck trying to pull it it out with rope around it it would not come out
Old Sep 25, 2009 | 05:15 PM
22RUCRAZY's Avatar
sounds crazy atleast you got it
Old Sep 26, 2009 | 11:30 AM
scottg96039's Avatar
Glad you got it, but I bet you were a little sorry when you did!!
Suckers weigh 987 pounds!!
Last time I took mine out it tried to kill me! heheheeeeee
And hey you got the pilot bearing out! They are usually miserable trying to get out.
Sorry about your bell housing.
yours Scott
Old Sep 26, 2009 | 11:43 AM
Naw it only weights about 200 pounds we are going to tap a few holes a s make a metal plate to cover the hole
Old Sep 26, 2009 | 12:25 PM
Mine's a 5 speed and with the transfer case on it weighs about what a honda car weighs altogether!! And a lopsided top heavy monster it is too!
First time I ever had mine out.........I built a little carriage for my floor jack and rolling it out all nice and polite and kahhhhhwhumpa!
Sucker turned turtle in a heartbeat..... carriage, jack and all!
Me, squeezed under the truck on stands like that... barely got away!
Life of a shadetree mechanic..heh
Found a better balance point from then on.
yours Scott
Old Sep 26, 2009 | 03:45 PM
I got a transmission Jack from harbor frieght it has a chain and larger wheel base so makes it easy
Old Sep 26, 2009 | 04:04 PM
refried's Avatar
I never had much luck with transmision jacks it seems like it wastes too much time getting it set up properly. I'll try it by hand first, resting it on my chest first then lifting it into place, If it dosen't go in right away something is wrong and I'll get a jack.
Pick up transmissions and transfer cases don't come close to what they weigh from a land Cruiser or a full size truck.
Old Sep 28, 2009 | 05:42 AM
83's Avatar
83
Am I the only one who thinks 83's came with 5 speeds?? Mines about as stripped down as they come and it has a 5 speed.
Glad you got it out.
I tried the bench pressing method to get mine back in, but even with the t-case off, it wasn't happening...even with a friend! I guess we're wimps. Or just don't really know what we're doing (pretty likely).
Old Sep 28, 2009 | 08:03 AM
dropzone's Avatar
Fossilized
no you aren't...more than likely someone had swapped a 4 speed into the 83 earlier...
http://www.4x4wire.com/toyota/faq/parts/
but you never know...
Old Sep 28, 2009 | 08:22 AM
83's Avatar
83
Thanks. Right, you never know, but it seems to be the common wisdom that by '83, 4 speeds were no longer available. Doesn't matter though, that's not his question..
Old Oct 14, 2009 | 10:22 PM
OldManYota's Avatar
I have a 5 speed out of an '83 and a doubled t-case. i have found a rolling floor jack with an extremely wide wheel-base and a larger lifting platform with chains. it starts its lift at about four inches and goes up to 22". with my lift i've had no issues lifting and dropping both trans and TC safely. Unfourtunately i got it used and there is no stickers for make. I have found a similar one in the catalog at the local auto supply shop, but it was over $1100 Canadian.
Old Oct 15, 2009 | 11:48 AM
Jeff D's Avatar
I've got an '83 2WD that came stock with an automatic (3 speed with overdrive... so 4 speed I guess?). Only seen one other '83 2WD that came with an auto, and really can't find much online about it. I think they're pretty rare.
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
