Pre 84 Trucks 1st gen pickups
strange engine combo
Old Dec 7, 2009 | 07:52 PM
wlabrum's Avatar
hey guys I goofed
I did not realize what i did when i put my motor together
i put 87 flat tops in a early 22r block and heads any idea what compression is
need to figure it out so i can buy a cam
Thanks
Old Dec 7, 2009 | 08:09 PM
xxxtreme22r's Avatar
hmmmm, does it run that way?
Old Dec 7, 2009 | 08:26 PM
camo31_10.50's Avatar
i woullddd saayy NOOO..since he still has to buy a cam...therefore i assume he doesn't have the motor put back together???
Old Dec 7, 2009 | 08:35 PM
My guess I highly doubt it will run like that. No matter what cam he puts into it.
Old Dec 7, 2009 | 08:41 PM
wlabrum's Avatar
motor has 20000 on it runs good 22 mpg
added header with 2 1/4 to flowmaster
32/36 weber on 2 inch open spacer
this motor wants more cam from what i can tell
but what one i buy depends on comp ratio
Old Dec 7, 2009 | 08:44 PM
wlabrum's Avatar
it will ping with just its best vacuum is 8 degrees over stock timing last motor wanted more than that
i understand later blocks were 2mm shorter like the earlier carb block
if so is this true????
Old Dec 18, 2009 | 06:51 PM
cougarbait's Avatar
The 84 and up had taller blocks. Might spin it with head off to see about the piston heigth. check this link. Very good factory info.
http://www.toysport.com/technical%20...tech_notes.htm
Old Jan 5, 2010 | 08:16 AM
wlabrum's Avatar
just checked compression 140 psi all cylinders
BushPig
Oct 29, 2022 06:26 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
ryerye13
Jul 14, 2015 08:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
