PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 22r new motor?
  2. 4.3l swap
  3. HiGH oil pressure breaking in 20R
  4. Finding the engine knock
  5. felt and rubber wipers
  6. 22r Loss of Power and Clicking.
  7. frigid zone options 79 80
  8. 20R Distributor Differences 1979-1980
  9. 83 pickup lift and engine rebuild
  10. Weber jet size for 20R?
  11. CA Smog solutions?
  12. double row TC 22r strange pinge/clack/knock from driverside under cab
  13. Strange Brake Problem - Fixed But Still Confused
  14. Speedometer swap
  15. '83 seats
  16. tail light problems after replacing sockets
  17. Is the W50 input shaft compatible with the W52/55/etc?
  18. Need to identify this 5-speed transmission from a 1980 20R pickup
  19. 79-83 Toyota dash mods
  20. 1980 L52 Shifter hollow rivet removal question
  21. New Weber carb backfire/popping. All out of ideas.
  22. Accelerator Pad
  23. Mecanical timing vs ignition timing question
  24. Wrong driveshaft flange pattern
  25. Pointers on High pinion v6 third install tomorrow
  26. blowing seals 20R
  27. Sticky Shifting Question, Revisited
  28. Swapping 5 Speed into my 83?
  29. 1994 Toyota 2L Diesel Motor To 1983 SR5 swap
  30. U joints
  31. Location of Accessory Wire to tie in new deck
  32. Timing reading doesn't make sense on 20R engine--locking key missing?
  33. Best OEM wheel reconditioner?
  34. Charge Lamp (Light) Relay... Don't have one!
  35. 22R rebuild
  36. frame swap
  37. 1981 Charge Relay/Light and Sensor light Always On Calif Truck <Solved>
  38. transmission swap W50 for W59
  39. removing fresh air ball grill
  40. 20R Venturi size ?
  41. L52 trans
  42. 33X10.5 R15 tires
  43. skid plate bolt size?
  44. 22r engine build complete
  45. first gen mud flaps
  46. Trail gear ubolt flip kit
  47. Yellow '82 long box
  48. 81 22r carb/vac issues?
  49. I've Developed a Miss
  50. Anyone ever Turbo a Carbed 20R or 22R?
  51. Violent Shaking When Starting off in 1st/Shifting into 2nd
  52. Carb issue on my 22R swap into a 79
  53. 1980 Suspension
  54. READ THIS Before you hack up your dash to install an aftermarket radio!
  55. 1982 4wd Power Steering leaking fitting - Banjo Fitting?
  56. 22r offenhauser intake thermostat ????
  57. Headlight warning beep?
  58. 22re swap ecu??
  59. 1980 20R vacuum leak? poor warm idle
  60. Ignition Key falls from switch from slight bumps?
  61. Stiff Brake Pedal After Rear Disc Brake Conversion
  62. 1978 Toyota Hilux Dually
  63. 1982 yota need help
  64. New Strange Sound when downshifting w/ video
  65. CHG Light - Gets Brighter with fan switch
  66. Blasphemous musings
  67. 83 22r toyota pickup ignition issues please help!!!!!
  68. Leaf spring questions
  69. Steering wheel
  70. Need new 22r head
  71. 1981 Truck Frame Dimensions
  72. 1981 truck Stock vacuum Line Diagrams
  73. No spark, GM ignition mod swap.
  74. Looking for new leaf springs...
  75. Help! No coolant flowing to heater core
  76. Whats your tire pressure up front?
  77. Leaf spring bushings
  78. Wheel bearings
  79. shifter offset is this normal?
  80. 22r belt issue
  81. Fixing dent in Wheel Rim edge?
  82. 83 pickup 11.5 drum brake upgrade?
  83. Water in oil after new head...then none?
  84. 81 to 83 pickup wiring harness swap
  85. 82 Pickup with sluggish throttle
  86. Hesitation
  87. 77 pickup terrible gas mileage what do?
  88. High-lux doorpanels
  89. 82 toyota dash lights and running lights quit working.
  90. Where to get individual carb parts?
  91. 2nd gear issues
  92. newer trans in a first gen
  93. Vacuum Caps
  94. 82 toyota heat barely works
  95. Electrical/Starter/Ignition Problem
  96. need help! vibrations 1980 pickup
  97. OEM Rims
  98. Power steering conversion problem
  99. Head Decking - How much is too much?
  100. My '81 Toyota 4x4.....yeah, it's got RUST!!
  101. Replacing seats in my 1980 pickup
  102. Help! '80 pickup alternator 3-wire plug--which wires go where?
  103. Any difference in the Celica 20R vs. pickup 20R heads?
  104. Finally got my solid axle truck
  105. 1983 Short Bed Trans Upgrade
  106. Vinyl Upholstery for 82
  107. Exhaust Manifold to Tailpipe Connection
  108. Weber causing fuel pumps to leak.
  109. steering column
  110. Max tire size 4 a 83 yota pu
  111. Questions on piston ring sealing
  112. Fiberglass Dash Pad Repair
  113. Apparently there's a huge toyota fan working at Disney!
  114. 1981 4X4 clutch getting air randomly?/ Wiper electrical issue
  115. Help me identify these parts please!
  116. 1983 HiLux RN38/Truck 4WD Drain Plug Bolt Size
  117. Electrical gremlin on my '81 Toy
  118. headers for a 81 4.3l swap?
  119. New Member w 1982 short bed
  120. Mirrors
  121. Intro, 82 longbed and new member
  122. Airtex 1330 mechanical fuel pump & fuel regulator
  123. 6' Flatbed on Longbed?
  124. windshield wiper motor
  125. 20R Bottom End Partial Rebuild Questions
  126. 4x4 Stock ride height
  127. '75 Hilux 20R Engine Removal
  128. New shoes
  129. Side Markers Lights Won't Turn Off
  130. 84 22r swap into 79
  131. drive line sourcing for ifs width rear 83 pickup
  132. Compression Results - Opinions?
  133. How many miles before the oil goes black?
  134. Looking for some Vintage JDM lights, but can't find them???
  135. 1gen speedo gear help
  136. Engine/trans/t case removal
  137. Seeking advice: stopgap engine swap
  138. 1983 22r Will Not Idle
  139. 1979 4wd 20R will not start without starting fluid
  140. 4Runner parts to upgrade my 82 truck with?
  141. Ignition Switch - Truck randomly dies
  142. Knock of some sort - video
  143. 1975 Hilux (20R) - Where's the oil going? Help reading compression and leakdown
  144. I have the goods! 77 toyota pickup vaccuum diagrams!
  145. 1982 22R Motor Rebuild advice
  146. 1981 Toyota Pickup 4x4 with wonky headlights
  147. Odometer broke at 260,000 exactly?
  148. Tire Size, Tank Size, MPGs
  149. looking to buy a 82, what to look for ? :)
  150. Idle Fuel cut solenoid circuit...
  151. Intermittent steering wobble at 35-40, 55-60 mph.
  152. So who's truck is this?
  153. Front end sway?
  154. Ruling out EGR issues VS. Electrical/other in only runs when under load 22r
  155. OEM Steering
  156. '75 HiLux Valve Seal Replacement Advice
  157. Two possibly dumb questions about a W56 swap
  158. 1980 Toyota pickup seat belt replacement
  159. Thought it was Rod Knock, it was the crank pulley... - TIPS?
  160. Just got fenders from an '83 4WD.....has fuel injected badge??
  161. Tie rod issues
  162. Gas pedal hook up on 80 2wd
  163. 79 front driveline spins in 2wd
  164. Can't find fuse
  165. Charge light issue minor
  166. Transmission Swap
  167. Racing Seats that will fit nicely in a 79-83 pickup?
  168. 22R Oil Pan Literally Stuck On! Help Me!
  169. Weber 32/36 to Weber 38
  170. Something stuck in my fuel line
  171. Repro floor liners?
  172. 1979 Project truck
  173. Weber Carb wiring hookup
  174. Torque Specifications for Chassis/Suspension for 81 Toyota
  175. Trans swap
  176. Will 79-81 front bumper fit on 82-83 pickup?
  177. all lights went out, 81 4x4
  178. Valve Cover Breathers
  179. 1982 Rebel Edition
  180. Water plate
  181. PS pump interchange?
  182. Exhaust port hole
  183. Anyone adapted a 2wd bed for a 4wd truck?
  184. Softtopper!
  185. Plug Read
  186. odometer stopped working 81 pickup
  187. 81 headlights dont work need help
  188. Best transmission to buy for 1983 4X4?
  189. Passanger door won't open
  190. will it fit: engine from 83 toyota van it is fuel injected into 1980 2WD
  191. FIPG Question
  192. which is simpler- pull trans. or engine?
  193. what years have the same doors as a 1982 2wd, 22R, 5 speed?
  194. 82 4x4 Toyota Pickup frame suggestions
  195. 1980 windshield wiper issue
  196. Aftermarket steering column U-joints?
  197. 22re swap
  198. parking brake cable
  199. Where in california can I get a complete 20r long block?
  200. I have searched... No power/No start. DWD.
  201. Fuel pressure
  202. 3rd Gen Pickup Engine swap?
  203. Aftermarket 2wd Suspension for 3rd gen pickup?
  204. Transmission Commonality/Swap? 1979 Hilux and a 19__? SR5
  205. Distributor Vac. Advance Diaphragm sources?
  206. Your experience with timing chain noises '79-'83
  207. Pre 84 parts source
  208. early diesel engines
  209. 87 Supra IRS in 82 2WD Pickup?
  210. Anybody in North Georgia that can help?
  211. 4 speed to 5 speed mini truck
  212. Three questions about LC/IFS front brake swap
  213. Weber Carb Mixture Screw/Jetting
  214. Vacuum Pressure
  215. Gasket for exhaust manifold tin? Is there something better?
  216. About to rebuild my knuckle, a few questions.
  217. Stick shift gets warm near transmission
  218. Noob alternator removal question
  219. front turn signals
  220. Fiberglass bed sides replace?
  221. 1976 Chinook, 82 diesel pickup or 81 pickup?
  222. Help with cam
  223. 83 toyota 4x4
  224. help with motor tap
  225. distributor
  226. Elocker flange vs 83 rear Drive Shaft flange
  227. Shifter knob throttle
  228. 20r to 22r stock carb swap.
  229. HOT hub, weird sounds, pulling and caliper leak
  230. Wierd Carb Issue
  231. Horrible noise in 4WD
  232. 22r 268 cam
  233. '82 Horn won't work well when needed?
  234. Body lift results in carb linkage misalignment
  235. 81 20r wierd weber problems
  236. 22re swap
  237. Rubber splash shields
  238. First gen not charging...
  239. 1982 Emissions hoses have me stumped!
  240. '82 carb running rich? dark/black carbon in T-Pipe
  241. Where are the Birfield joint repair kits?
  242. 1981 4wd 22R power steering conversion Help
  243. Save Gas? Idle cut Solenoid use with remote switch?
  244. stumped
  245. 1981 1st gen L-52 slave cylinder help
  246. I really need some 4:30 ring and pinion!!!!
  247. What are radio options for a 83 pickup
  248. can i swap 1987 window gear for 1981
  249. Electrical Problems
  250. Is it an SR5 ????? Yeah sure!
