Pre 84 Trucks 1st gen pickups
1gen speedo gear help
Old Feb 1, 2015 | 06:30 PM
Lons81's Avatar
Hello all. I'm working on my build and have run into a problem concerning the speedo drive gear. I'm in the process of wanting to convert all my gauges over to something like Autometer's electrics instead of the stock gauges. In looking for a speedometer, most all that I've found will accept only a .104 square drive cable, but the stock speedometer drive gear has a round end with a slot. I've looked over the web for a conversion and haven't found a replacement drive gear for Toyota that has a square drive. I have a L52 5 speed gearbox. Any ideas/mods would be very helpful to accomplish my gauge upgrade project.
Old Feb 1, 2015 | 08:17 PM
dropzone's Avatar
Fossilized
Been awhile since I had my dash apart.
it there enough metal on the end of the speedo cable to could reshape it?
Old Feb 2, 2015 | 08:04 AM
Lons81's Avatar
Smile
There probably is enough slop in length, but most all aftermarket speedos have a 5/8"-18 threaded input, where the stock Toyota speedo cable has a slip fit and snapped in at the gauge end. Guess it's time for a custom made cable, huh
Old Feb 3, 2015 | 07:04 AM
Lons81's Avatar
My problem has been solved. In talking with the guys at the speedo shop, I'm going to install a Correction Box with two cables. One cable comes off the case with the correct hookups going to the box and another cable from the box to the speedo. This way I can get the speedo calibrated to the actual miles traveled in a measured 5 or 10 mile test and have the correction box dialed in. If I change tire size, it will be a breeze to re-calibrate the box ratio. I can mount the box anywhere I please, so nice to have options when upgrading the old beast.
That's my fix and I'm sticking to it Thanks
Old Feb 3, 2015 | 02:59 PM
1st Gen Crawler's Avatar
Got a link to the correction box you will be using, or know specifically what it is? Could be a good option for a lot of guys on here.
Old Feb 3, 2015 | 03:17 PM
Lons81's Avatar
I plan on using their products when I get ready.
http://texasindustrialelectric.com/7...er_Adapter.asp
Dieselmann
Feb 19, 2019 02:57 AM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
norcal98
Aug 10, 2015 06:20 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
