View Full Version : Pre 84 Trucks
- looking for OEM slave cylinder for 1980
- water pump timing cover bolt twisted off, will it leak?
- [?] 22r w/ Weber 32/36
- 79-83 factory green color
- Been having fun
- 1983 Pickup Caster Angle
- 81-83 2JZ-GE/GTE Swaps?
- 77 20R won't stay running
- 81 22R will not idle
- help! what gears am i running?
- No gas
- Oh Crap... motor mount blown!
- power steering write up
- Rattle time!
- what beds interchange???
- oil pan leak
- wiring harness swap
- [?] Distributor vacuum setups
- Best online site for rims
- 83 5-Speed Tranny Fill Plug
- Brake Rattle
- franken yota
- Strange idle problem 22r
- Fuel lines under intake
- L52 swap in morning TIPS!!!
- New Carb/1983
- will a dual chain kit fit on a 83 yota
- So I had an awesome weekend
- Lights not working.
- Water line questions
- Intake question
- Carb Rebuild Problems
- Problem with Temp gauge
- ? On Smog pump/ ac compressor
- 20r to 22r swap in 1980 pickup
- I need some help from people with carbureted vehicles
- 1981 toyota 4x4 long bed project
- Diesel Injection Pump Info?
- YotaTech App!!
- carburetor linkage question
- Where to find a tie rod center link?
- speedometer cable on My can O worms
- Some ideas
- cannot find a Throttle linkage
- Heater Core Replacement
- Fuel pump problem. 86 22r in a 79
- oil blowby every where
- Replacement Bilstein Parts
- How To Keep Your Toyota Alive 1975-1987 Repair Manual
- Will it start/run without a dash in?
- power steering problem
- 79 wont turn over after swap. Starter?
- Aisan Carb Rebuild Kit
- How to get fuel gauge working again on 82 Toyota pickup??
- 1980 4x4 need help to get to work
- Does this look right?
- My 1978 sr5 20r resurection
- CARB header for my '82
- 82 idle, whine power loss problem.
- Questions on taking out windshield and re-installing it on 82 pickup please...
- Need ideas for durable and easy to clean floor lining for 82 Toyota pickup front cab!
- shimming knuckles
- DESMOGGING 22R info-Links to threads
- truck runs fine then stalls
- need help on removing a broken bolt
- Clutch diagnosis and carb rebuild questions
- Shift arm troubles
- Suggestions needed...
- Sock gone?
- Newbie here! Weber carburetor questions.
- 22r Ignition timing
- 1988 22RE in a 1981 not cranking
- Help..Rounded off tank bolt.
- So that little hose thing at the bottom of the radiator
- A 0.00$ build how to build my 83 SR5
- trailor lights
- 1983 Trailblazer
- Wheel Spacers and Bearings
- Painting the metal dash parts while dash IN the truck?
- 2 and 4 wheel beds
- 83 4x4 swap
- Restoration thoughts
- redline cv grease how much??
- Is this a good deal on this dash bezel?
- Power steering help!!!
- 81 toyota pickup 22r carburetor help
- 79-82 oil pump drive gear?
- Crap, I bent my yoke
- Fuel line from gas tank question
- Awesome 4x4 Camper
- Looking for some info
- My '83 Toyota
- Looking to buy a full gasket set. Anyone buy from these guys?
- Help finding a 76 fuel sending unit
- Bilstein 5100 Part Number??
- 1st Gen on 2nd Gen frame?
- Lettering for tailgate
- 4wd, 2wd bed differences
- Help identify this vacuum part
- Sources for Toyota part
- Newbie to the site with a "new" 76 longbed
- vents at top of hood
- Welding bed sides onto 2nd gen bed?
- 22r hedman 39400 feedback!?
- Thermostat seal
- What gears do yall reccomend?
- Just thought id share this with you guys
- New 82 and i need help
- Single / Double row timing chain.
- Calling all stout owners!
- Oil & Water Pump
- W50 transmission retaining clips?
- 20/22R hybrid timing issuse
- new steel bed sides
- way to much advance 82 22r webber
- Double check my U-joint Part#'s please
- elocker in 1st gen?
- new hoses under the hood
- 1st Gen Graphics?.................
- Sealing the timing chain cover where it mates to the cyl. head
- Roll bar info, questions.......
- 82 timing chain alignment?
- Turn Signal / Multifunction Switch / Horn Success
- 1983 crankshaft pulley problem
- Weber Carb Advice?
- Need help with weber!!!!!
- Bed sticker found........
- any one heard of weber 26/27
- Vibration with clutch out
- Valve rockers aren't aligning?
- New here/79 pickup issues.
- Knuckle question
- 911 Electrical Help
- Which type of side view mirrors?
- tcase fitment
- 83 4x4 motor mount fitment issue
- Ahhhhh engine craziness?
- 83 Radio Ideas
- Running GREMLINS
- High Mileage
- Headliner replacement?
- Headgasket, do I have to replace it if I loosen the head bolts?
- need help finding a limited slip
- truck stalls everytime i press the brakes
- 22r overheating.
- 81 Timing chain replacement
- 1979 coil igniter
- 20/22R compatability
- Whats the CHEAPEST way to put a high output alternator in a 1982 22R?
- Cool Toyota Lineage Website
- 22r annoying oil leak!!
- Anyone done a gas tank swap?
- Needle valve filter/screen
- Newbie looking to buy
- accelerator pedal swap
- best prices on new fenders/ body parts?
- 1st Gen brake question
- electric choke not working
- 82 trans swap questions
- Restoring a 1979 Dually 4x4
- Heater coolant valve?
- hey just got a 1976 toy truck
- 1982 front driveline cv joint bad
- 1979 Hilux wont turn over
- 1981 Mini Truckin Build up
- doug thorley header install
- 83 a/c not working
- front axle rebuild...
- Trail Gear Trail Safe vs Marlin Crawler EcoSeal Inner Axle Seals
- 1979 4x4 at a Crossroads
- brake fluid all under truck
- distributor
- 82 22R BVSV Bypass?
- Rear Center Caps...
- Oil in radiator!!!
- Ups&downs!!!
- New Weber if all works out!
- 79 20r Fuel Mystery
- Whats up? new here. got a new toyota
- '82 22R Idling Issues
- Dash Cluster Nightmare! (signals, tach, battery, temp, etc)
- 22R super fast overheat (Real or Not?)
- 1980 pickup starter switch
- transmission leaking through the bellhouseing
- Center Rear Hub Cover Pic wanted...
- Crazy Idea but seems like it would work
- brake pad install- no wire clips!
- W50 transmission bearing sizes
- rebuilt. lots of work
- Removing crank. Do I need to remove the timing chain housing?
- Help with new u-bolts
- ? on waggys for RUF upgrade
- starter spins without turning key when trying to jump start
- Power Steering Conversion?
- rust inside frame
- 1982 pickup signal and hazards dont work?
- Need measurement of 1979 - 1983
- 1979 20R head on a 93 22R block, will it work?
- 2rz swap
- rust windsheild... need help!
- Tires and Gearing 3.91 vs. 4.10
- water in tailpipe
- knock in top end/ valve clearance??
- 1979-83 Toyota A/C systems
- Water Temp Question
- Stereo install
- Need some help: 1st Gen Truck Alternator noise
- 1980 header fitment
- Got a 1982 , now the fun beings
- 1st gen 4Runner to 1st gen pick up My 83
- help me identify this screw on the weber 32/36
- USA style fuel door
- My new seats!!!!!
- Ignition superslueths needed 77 starts then dies!
- Rear view mirror internals part number
- 81 2WD SR5 Longbed
- weber vacuum leak at base
- Taking out leaf springs - what to expect?
- head shaved .030
- New seats with no welding or brackets
- 1980 20R Engine Bay clean up and last minute Troubleshooting
- Pic request..please
- factory A/C install
- new 22r
- Help guys I need a new exhaust manifold many ?'s inside plz look
- !st Gen Production Numbers??.......
- Temperature gauge needle, I think I screwed something up
- 1982 air condition wiring
- Runs, but wont start???
- new header, now truck is running rough?
- Maintenance Schedule for 20R chain
- 81 SR5 4x4 high problems
- New 1980 pickup owner
- 79 4x4 20r weber conversion help
- 1983 Toyota Diesel SR5??!
- What to do with my 81?
- 20R Weber Troubles..HOT Exhaust
- Anti oil drainback? 82 PU 22R
- headers and exhaust 82 pickup 4x4
- 20R/22R EGR Valve
- Driveline vibration and output seal?
- 1990 Frame under an 83?
- Idle mixture screw, which way to lean?
- Blow by
- starting issues, real bad.
- Just purchase 1983 sr5 truck
- Weird starting issue with my 82 22r.. little help would be nice
- T case mount?
- 79 Rebuild/Restore Project Brittany
- Was 5 spd an option on DLX?
