Pre 84 Trucks 1st gen pickups
redline cv grease how much??
Old Jun 26, 2013 | 03:52 PM
catfish21's Avatar
Yeah I'm gonna try and rebuild my front end this weekend and I have decided to use the redline cv joint grease, well this stuff is pretty steep in price so I was woundering how much grease you guys had to use from past experience I want to buy enough but I don't want to get more than I need thanx
Old Jun 26, 2013 | 06:08 PM
slacker's Avatar
I will traditionally use 3 "tubes" .. and only use white lithium in the hubs
Old Jun 26, 2013 | 06:47 PM
catfish21's Avatar
Well the red line grease is a synthetic has anyone used this or do u recommend just the regular white lithium
Old Jun 26, 2013 | 06:53 PM
slacker's Avatar
did you not understand my above post ?
Old Jun 27, 2013 | 01:53 AM
catfish21's Avatar
Yes father I want back talk you anymore
Old Jun 27, 2013 | 03:58 AM
catfish21's Avatar
Man when I started my restoration and found thus site I thought this was the coolest thing to get help and advise on certain things, but if you don't say just the right thing people jump all on your ass. It's ridiculous I see this every day on here people jumping down someone's throat for saying something you don't want to hear. Grow up and have some courtesy for people not everyone is as mechanically inclined as others. I have let people talk to me crazy on here for the last time and I have bitten my tongue for long enough
Old Jun 27, 2013 | 06:14 AM
snobdds's Avatar
I'm sorry, but when did we become responsible for your feelings? Your reading comprehension sucks, to say the least. If you reread, slacker clearly says the redline grease is fine for your knuckle rebuild, but only use white lithium grease in the hub's.
How did you get so confused and butt hurt?
Old Jun 27, 2013 | 10:40 AM
kawazx636's Avatar
I'm subscribing only to view the fireworks on this thread...and of course to know exactly how much grease to use on my CV joints LOL
Old Jun 27, 2013 | 11:14 AM
93Xtra-Cab's Avatar
We usually jump down peoples throats when people ask questions that have been answered multiple times before, just like this one. A simple search would have given you the answer.
We take time out of our busy schedules to give great technical information and answer peoples questions. When someone is too lazy to read and comprehend the information that's right in front of them and then makes a blatant smart-aleck comment when we're trying to help them, of course we're going to get mad. He wasn't "talking to you crazy". He was giving you a simple answer.
We're definitely not as bad as other forums. Try going on pirate for technical information. I guarantee you'll be back.
Old Jun 27, 2013 | 11:48 AM
RSR's Avatar
RSR
Slacker -- why white lithium instead of general lithium?
catfish21 -- might want to look at amsoil for synthetic greases. they're probably cheaper and have a much larger range of options.
Also, the FSM calls for general multi-purpose grease in the hubs. So the redline grease you're planning to use should be fine there.
Old Jun 27, 2013 | 12:03 PM
catfish21's Avatar
Thanks for the info and I'm gonna look into that
Old Jun 29, 2013 | 04:11 PM
slacker's Avatar
I didn't look at the OP location , so it wont really matter for him , but in a colder climate , it makes locking and unlocking hubs much easier in the winter
Old Jun 29, 2013 | 05:25 PM
StewsRunner's Avatar
Not to thread jack but does CV grease expire?
Old Jun 30, 2013 | 12:21 AM
RSR's Avatar
RSR
Stews -- probably eventually, but typically your cv boots wear out before your CV grease fails.
I consider CV grease worn out when the boot tears, as that's the only time grease should be escaping and dirt and other abrasives introduced into the CVs.
Old Jun 30, 2013 | 12:23 AM
RSR's Avatar
RSR
Thanks slacker. I seemed to recall, but don't know that it's actually based on reality that white lithium attracts water. And my rule of thumb for white lithium is only use when you need to know that all your old grease has been removed. Which I don't think applies to our trucks...
Old Jun 30, 2013 | 05:25 AM
Sorry, I meant new grease.. I bought some tubes of grease back in October and I was curious if, since they are sitting and not being used, is there any chance they can become useless? It does not sound like it. Thank you, Sir!
Old Jun 30, 2013 | 09:56 AM
MudHippy's Avatar
Grease(of any kind) never really goes bad. So long as it's kept clean and used within the specified temperature and pressure ranges, it will virtually last forever. However, if it's sat around for a LONG time UNUSED, the oil might start to seperate from the soap. But all you have to do is remix it, and you're good to go.
Most lubricating greases are mixtures of an oil and a soap. The soaps are dispersed into and viscosify oils to form the stable gels that are called greases. Grease made with lithium soap ("lithium grease") adheres particularly well to metal, is non-corrosive, may be used under heavy loads, and exhibits good temperature tolerance. It has a drip temperature of 190° to 220°C (350° to 400°F) and it resists moisture, so it is commonly used as lubricant in household products, such as electric garage doors, as well as in automotive applications, such as CV joints. Lithium-containing greases first appeared during World War II, and were perhaps the first large-scale commercial application of lithium compounds.
Some formulations also include PTFE or other substances, such as molybdenum disulfide. For high-performance and higher-temperature applications, lithium greases have been superseded by other types of lubricants.
http://en.wikipedia.org/wiki/Lithium_soap]
Dude...WTF is with the screwed up links? That's a bunch of BS!
Old Jun 30, 2013 | 03:38 PM
slacker's Avatar
been usin' it for 30 years , and never had any issues ... so it's just a suggestion from experience . NEVER had any issues with water in the real world
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
Pri$erulz
Nov 17, 2019 08:03 PM
pickle6415
Oct 19, 2015 08:08 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
