Pre 84 Trucks 1st gen pickups
1988 22RE in a 1981 not cranking
Old Jul 5, 2013 | 11:55 AM
andrewd's Avatar
I bought a 1988 pickup with the 22re and I have been working on getting the engine, tranny, and gas tank switched over to my 1981 pickup. Long story short, I have gotten the engine ready to fire, and when I turn the key, nothing happens. The lights work, but I just can't figure out why it won't crank.
Could it be ground related? I've checked all of them and they seem to be good, but lets just double check I have them correct:
Engine bay:
-Battery negative to engine block
-Engine block to firewall
-Alternator ground from harness to p/s bracket
-Wiring from intake manifold to intake manifold ground
-Harness near fuse block to fender
Cab:
-Steering wheel column to body, not sure if this is correct or not
-Harness near fuse block to body
-Unknown ground from harness to body
Does anyone think it could be anything else besides the grounds?
Old Jul 5, 2013 | 12:04 PM
yodafan93's Avatar
it wont turn over at all? is it clicking or doing anything? or just totally silent when you turn the key? also did you swap over the entire harness? and its efi still?
Old Jul 5, 2013 | 12:06 PM
andrewd's Avatar
It doesn't do anything at all, silent, no clicking. Yes, I swapped over the entire harness and took the old one out. I even replaced the steering column in hopes it would be easier to figure out the wiring.
Old Jul 5, 2013 | 01:11 PM
yodafan93's Avatar
do you have power to the fuel pump? id start with the grounds. id check the fuel pump and starter first, pull out the old wiring diagram and see what all is in the starting circuit.
Old Jul 5, 2013 | 05:28 PM
dropzone's Avatar
Fossilized
did the harness you pulled have a clutch start cancel?
young buck
18
Aug 27, 2018 02:40 PM
mskalmus
May 28, 2017 07:51 AM
Backcountry411
Jul 24, 2015 08:06 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
