PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25
  1. About to own an 81, a few questions if you don't mind.
  2. 79-83 Wheelbase Measurements LB vs. SB
  3. Vacuum Advance Question
  4. FRONT driveshaft
  5. 20R efi option feeler
  6. stock or hy-steer
  7. 1981 Diesel
  8. carb linkage B.S.
  9. 83 to 81 Parts Interchange.
  10. 98civic seats installed!
  11. Driveshaft bolt size?
  12. Shifter Boot
  13. Front end Alignment? for '82 4x
  14. 1979-83 TOYOTA 4x4 Truck Pickup SR5 INSTRUMENT CLUSTER
  15. My new Rig....!
  16. Cluster Swap Question
  17. Headlight/Grill swap?? ('81 to an '82)
  18. Birfield joint
  19. Anyone running electric fuel pump on 22r
  20. transmission pics please
  21. Truck hunt!
  22. Engine swap options for a 1st gen pickup
  23. wheels
  24. Weird clutch problem
  25. What is my problem?
  26. 85 bed to 79 truck
  27. off topic
  28. Brake lights, Headlights, and fuel pump died
  29. mud anyone?
  30. tranny=gearing?
  31. Ignitor for a 1980 20R Truck
  32. 83 yota swaping in 91 drivetrain
  33. 75 toyota 2wd
  34. Moon Roof Leaking
  35. So my buddy wrote a song about the Toyota Trekker
  36. Overcharging Battery....???
  37. Engnbldr ????
  38. Rim Size question
  39. Weber Carb
  40. W58 into 1980 4x4
  41. What weber carb to use?
  42. 83 22R fuel problem???
  43. Ring and Pinion Swap
  44. interesting 1st Gen Conversion
  45. reverse poping out of gear??????????
  46. Need some help !
  47. 83 truck gremlins
  48. 82 carb
  49. 1st Gen Tail light idea:
  50. first gen driving questions
  51. Brake and Batt. light won't turn off.
  52. Won't steer right??? 1983
  53. whats this
  54. whats this
  55. price quote for 81 4WD pickup?
  56. Looking at this one...whadya think?
  57. Bad luck !
  58. '80 Carb
  59. TRD E-locker install WIRING HOW TO PLZ!!
  60. Carb base gasket
  61. Need a 5 speed transmission for my (don't laugh) 1980 Yota 2 WD
  62. carb icing
  63. '81 Knuckle/Pitman arm Ball Stud Flip
  64. v6 radiator in first gen.
  65. 1982 pickup: odd symptoms
  66. bolting a 87 tranny to a 81 22r???
  67. Hysteer pros/cons and whos better??
  68. heater control valve
  69. Frames
  70. 20R: Weber 32/36 DGV or 38 DGES
  71. 81 4x4 Insight
  72. coolant
  73. floor pans??
  74. 82 22r wont idle
  75. Coil Ignitor!!!! Please Help
  76. driveshaft
  77. 350 motor swap
  78. shifter assembly
  79. sun roof question
  80. HUB LOCK (what YEARS will fit 80)
  81. New to own a 79' with starter ??
  82. 81' california smog help
  83. New Tach, New Problems
  84. Your Trucks Top Speed
  85. screwed and tattoed
  86. 22re swap from celica into '80 toy truck
  87. Sway-Bar
  88. Sports truck!
  89. Today is a sad day.
  90. Wheel Spacers
  91. FINALLY! daytime pics
  92. calipers
  93. Blinker question
  94. 1981 truck lift
  95. Carb is Mega-Squirting fuel...
  96. Attn: Colorado
  97. (brakes) Load Sensing Proportioning Valve
  98. '82 22R in '88 4Runner (EFI)
  99. Front Main!!!!!!!!!
  100. 82 Pickup Passenger side window issues
  101. 4 speed to 5 speed conversion
  102. HELP!!!(oil pan gasket)
  103. Problem starting my 83
  104. seafoam
  105. carb questions
  106. Carb freeze -up
  107. Side Clearance Marker Lights
  108. Oil Blowing Out
  109. Floor Mats
  110. 350 headers
  111. vibrations??
  112. 79-83 bumpers
  113. heater doesnt work right
  114. Ignitor/Ignition Module Replacement.
  115. Bed Liner?
  116. 82-83 Toyota Dash bezel
  117. cb antenna
  118. Rip's Rigs
  119. Spring packs.
  120. 81 clutch replacment
  121. cab change
  122. I want one
  123. Need 83 Carb Pic
  124. 32/36 weber installed!
  125. 1/2 ton runningh gear under 83 pick up please help
  126. wires
  127. idling high
  128. Propane Conversion
  129. 1980 front differential Noisy??
  130. cd player mount ideas
  131. problems using pre '79 style coil on '81 22R?
  132. stock muffler inlet size
  133. Air Injection Pump, Do I need it ????
  134. 1981 Trekker for sale in Sacramento
  135. torn between a truck and a sports car???
  136. new ugly old '79
  137. I had to post this, 81-83 Pick up in Minneapolis Looks Awesome!
  138. skyjacker lift kit 5," 83pickup
  139. 82 longbed driveshaft
  140. Info Help 21r
  141. help...PLEASE!!!!
  142. Engine wont Idle Warm
  143. gas station overcharge fuel capacity
  144. Wipers Act Odd
  145. Very Surprising!
  146. figured out my idle / alternator issues
  147. Is this an old Toyota (hard to tell)
  148. 20R/22R Distributor
  149. Weird Temp Reading
  150. New owner here...couple Q's
  151. 81-83 22r swap
  152. 83 Bumper
  153. High Steer question
  154. looking to rebuild my 22r
  155. 3rd member questions
  156. 1980 Truck Towing Capacity
  157. Hey Rowdy235...and others re: carb/charge
  158. 22r carb idle races...
  159. Show Your First-gen Mods
  160. Homebrew Fuel Injection
  161. Driveshaft question.
  162. will these rims fit?
  163. Two quick questions...
  164. Anyone good with wiring?
  165. 1980 floods out or sputters out???!!!
  166. 1980 emissions and vacuum stuff
  167. 78 4x4 I found, Wolverine conversion
  168. 83 issues
  169. So I found this for $375, now what??
  170. hell yes 8$
  171. 82 vs 86 rear end
  172. super charger .. maybe :)
  173. 81 Wiring diagram
  174. doing the 63 chevy spring swap, had one question
  175. transmission
  176. Crossover Steering
  177. Parting Ways for project of my own...I hope
  178. new paint!!!!
  179. Transmission (swap?) question
  180. Engine mounts???
  181. 83, 79 grill
  182. 7.5 carriers
  183. Tranny Scream
  184. Lockers VS Welded
  185. 78 4 to 5 speed swap
  186. The Blue Truck is getting lowered...
  187. Seats
  188. Parts search for rare 22R Diesel (82)
  189. Quick "what's it worth" Question...
  190. Trailer Hitch
  191. Anybody know where to find a gas door?
  192. carb backfire/ motor running backwards
  193. Body lift shifter problem
  194. Hard starting 83
  195. Rockguard or Chipguard suggestions?
  196. Transfer case output shaft seal and bearing?
  197. '80 makes clicking sound in front end in 4wd
  198. Place your bets.[no oil pressure]
  199. 63" Rear Springs 82 Toyota
  200. Mounting a canopy.
  201. My Electric A340 shifting
  202. transmission
  203. Heater Question
  204. Oil filter. 22R. 1981
  205. Gear oil in trans.
  206. Rear Main or Input shaft
  207. Weber 32/36 Problems (20R)
  208. 1981 pickup vacuum problems
  209. craigslist find...
  210. Lights?
  211. 20r/22r motor not running right ...
  212. 80 4x4 wont move
  213. Rusty box thread
  214. thinking of buying a 1982 yota 4x4
  215. 1982 22R Carb Issues
  216. Tranny Swap
  217. vacc. lines with weber carb?
  218. Picking up and 81 22R Toyota Pickup 2WD
  219. 22R Front Crank Seal. 1981. 2WD.
  220. 20R to 22RE 1979 - EFI Swap Questions
  221. Blew a seal.
  222. hard starting/ smoke out of carb
  223. 2" Wheel spacers
  224. Hoping to own an '83 truck soon...
  225. 83 22r Pickup
  226. Starter goes Click
  227. Rough idle when engine is cold
  228. Lift help.
  229. Stock Wheels
  230. Charging\Alternator\Regulator Issue
  231. '83 Heater Hose Diagram?
  232. How much lift can I do?
  233. What are anco hubs???
  234. Just bought an 80 w/ lots of rust for $100 having a clutch problem...
  235. 1983 Toyota fan hitting shroud
  236. New to Forum. Just started Building my 1980 4x4 shortbed.
  237. Pulling to the right
  238. 22r blowing oil from valve cover into air intake
  239. I finally did it...
  240. 82 22R Will Not Start HELP!!!
  241. Drivetrain/Suspension option for 1981 2wd?
  242. my 80 build up
  243. 81 3rd member trade
  244. Chromoly rings
  245. 1982 Toyota: Valve Cover Gasket Replacement
  246. Buying Engine Have ?
  247. Steering column issues
  248. price of a good rebuilt 22r
  249. 1982 Pickup: ID oil leaks
  250. 3rd gen box on a 1st gen?
