Pre 84 Trucks 1st gen pickups
Vacuum Advance Question
Old Mar 5, 2008 | 11:43 AM
WSUWESTON's Avatar
I am running a weber 32/36. There are 2 hoses coming off the dist. Which one should I hook my carb up to? I have seen some pics with them hooked up to the forward one. Do you just plug the unused hose?
Old Mar 5, 2008 | 07:57 PM
Scooby098's Avatar
I only have one hose my self So I would think just plug the other one
Old Mar 9, 2008 | 07:37 PM
84sr5yoty's Avatar
Use in the inner diaphragm, the one closest to the motor.
Old Mar 9, 2008 | 08:03 PM
WSUWESTON's Avatar
Thanks, should I just plug the other one?
Old Mar 10, 2008 | 12:13 AM
84sr5yoty's Avatar
No need to since it won't cause a vacuum leak.
You may want to check the operation of the inner diaphragm on the vacuum advance can. The inner one on my 84 went bad 5 years ago. Pull a vacuum on the diaphragm by using a vacuum pump or just suck on the vacuum hose and put your tongue over it. It should hold perfect vacuum indefinitely.
Old Mar 10, 2008 | 10:15 AM
WSUWESTON's Avatar
Thanks for the help
Old Apr 5, 2008 | 09:42 PM
s8ter58's Avatar
now on that you want to use the lower one on the vaccum advance and leave the other one open cause that is your atmosphereic preassure.DO NOT PLUG IT
icentropy
Sep 16, 2020 02:47 PM
oldirtydirt
Feb 23, 2020 09:30 AM
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
88yodabasket
Jul 13, 2015 01:32 PM
