Pre 84 Trucks 1st gen pickups
1980 front differential Noisy??
Old Dec 11, 2007 | 04:37 PM
phreetogo's Avatar
Got my truck running nicely in response to my previous posts. Thanks for all the advice.
Now we had our first big dump of the year and I got some miles on my 4H gears. I was just curious how much noise these old differentials make. It doesn't sound like clunking or too noisy but it is definitely noticeable while driving. Makes kind of a rumbling sound. just curious what yours sound like and if it is normal to hear it or do I have problems?? Thanks again. John
Here's my beast.
Old Dec 13, 2007 | 07:27 AM
semo's Avatar
noise
Do you know why when I get the 4wd going it cranks every time I make a turn and it doesn't when going stright.
Old Dec 13, 2007 | 07:34 AM
dropzone's Avatar
Fossilized
Here's my beast.
looks like a clean truck...as far as your front diff noise, I don't think a lot of noise is normal...check your fluid level, I think it should be about up to the bottom of the fill hole (that is where I have filled mine to, I could be wrong)..check your u-joints for free play, check your pinion for slop too... sometimes the pinion bearing goes bad and has too much free play...if there is water in your pumpkin (milky/coffee like color-you may have some damage since the gear oil has been floating on the water)...
Have you lubed your birfields recently? also it is going to bind in 4WD on hard packed surfaces...
80Truck
Oct 12, 2025 07:25 PM
Ladythump
22
Nov 9, 2015 08:53 AM
ripp96
Jul 25, 2015 02:32 PM
scottyg486
Jul 19, 2015 05:34 PM
AaronM
Jul 8, 2015 07:15 PM
