View Full Version : Pre 84 Trucks
- Old Centerline wheel
- tailgate swap
- new to the forum just wanted to introduce myself
- 1980 toyota pickup lift ?s
- 1980 4x4 oil and amp gauge not working, hasnt ever worked
- Lost power
- 1978 2wd to 4wd SAS covnersion?
- Old RV dually axle issue
- makes grinding noise in 4wd when turnnig sharp.
- 83 22r head gasket help needed
- 1980 Pickup: High Beams do not come on.
- POST pics and info of 1st Gen Long Bed Camper Tops
- High volt reading / blown bulbs on '83
- Diesel Emblems?
- Engine vibration
- Clutch Job Pricing? Conondrum...
- Tuning Mikuni 44phh carbs
- what kind of lockers should i buy?
- Trans / t case mount
- 81 long bed lockers
- 1979 Toyota Shifter seat - bushing, side mount
- Heat out of center vent?
- 83 truck with 21iu motor?
- 82 shifter issues-spins when in gears
- Steering stabilizer suggestions!?
- Shackle questions
- Fuel injection
- Throttle Cable Questions
- High idle
- 20r motor
- problem with electric choke?
- Noise and rough running after cylinder head rebuild
- 81 4X4 brake question
- New to me 81 SR5
- blinkers warning flashers Headlight assembly switch
- Go Rhino front Diff gaurd
- VSV? TVSV? Vacuum Issues?
- Question on swaping 82' 22r into 22re
- Interchangeable body parts between 2wd and 4x4?
- Heater Core, $65 but how much TIME
- parts sources for used parts/bumpers etc
- 80 toyota 4x4 trans question
- Oil leaking out of vent line filter?!
- Trouble with my Tach 82 22r need a little help please
- lack of power! lol
- switching tranny outputs?
- 82 space cab info
- Mikuni sidecraft, found a set for pretty cheap
- Lost every gear but fourth?
- transmission question
- 22R wont idle= sometimes?
- Help! Head Gasket
- Transmission Swap
- To the L50 trans guys.
- Swapping a 5 speed into my 4 speed '81 4x4
- 1981 tach
- 81 pickup wont charge battery
- Fender, and fender emblems
- Block Heater
- 83 Pickup FSM
- New to me 83 with A/C problem
- 1981 22r Glowing Manifold
- 5 spd on a 20r?
- My 81 pickup
- Tan/brown Interior paint..close to OEM
- Ignition
- 81 solid axle
- 83' very jerky when maintaining speed and during slow acceleration
- Pre 84 parts
- New to me 1982 toyota 4x4
- Transmission questions
- Help me decide 22rte or stay 22r
- transmission bushing for l45 side sifter
- Looking for Local CALIFORNIA Yota Buff???
- Advice please: 1st Gen truck saggy front springs
- gauge cluster
- running rich...
- New member and first-time Toyota owner here
- My rustbox '80 slooow build thread
- Trouble with 82 electrical - dome lights, gauges, heater blower, please help...
- Dual Cases Triple Sticks!
- May need an axle..brake pedal pulsation
- I finally joined the club! My New to Me '83
- what do u think about shackles?
- my 83 build
- 4.7 Transfer case gears
- 83 charging problem
- 1982 wheel question stock or no?
- need alternator help '79 toy: wiring using '85 22R alternator
- Weber 32/36 is almost done. Just a few questions.
- 22r Carb on 20R completed, but have a question
- carb snorkle ???
- questions about swapers
- New guy with a 78 pickup I have several ?'s
- Cam and Carb questions
- "death wobble" on a 83
- driver side rear marker light
- Electrical Radiator Fans
- 1983 yota electrical
- Starting issue with desmogged 22r
- Stalling issues at low/normal idle
- Valve Rapping - '82 22R
- 81 2.4 Pick-up rwd coolant temp sensor
- Racing Bucket seats in 1st gen trucks
- Shakes Bad
- propane questions
- Truck dies once hot
- EGR Removal
- 1980 diesel 5spd 2wd pickup
- carburetor "stumbles" after EGR removal
- Bent Valves
- Any good 20R carb rebuild shops out there?
- 83 22R wont start
- 1980 toyota need motor info
- oil pressure adapter
- 79 short bed 4x4 stock exhaust....
- Battery Tray replacement metal
- Questions about the weber 32/36 and other webers
- toyota stout?
- 351w in a 82 4x4
- 4WD Spindle-Hub seal deformation.
- Fuel line routing for 22r
- Toyota Newb need some help
- 81 p/u power steering
- Help! Need a header gasket to fit a 22R Downey header
- 3rd gen rear springs in a 1st gEN Truck
- 1 Wire/ Elec Fan
- Remove 1st gen tie rod ends from knuckle
- A340F duals in a '82 w/22r
- My New 79 Toyota (w/ engine knocking)
- 83 Frame Repair
- What kind of problems might I run into with this 83 Yota pickup?
- 81 P/U gas tank sending unit
- 80 LB bed liner and camper top
- need egr help asap
- New Owner, ?'s about suspension and steering
- cb mount
- Engine dieseling when shut off
- Which Clutch
- First time gear install Tips or advice?
- 20R Runs HOT. [Video]
- 5.29 gears and 39.5s?!?!?!
- 83 toyota pickup wont turn over.
- Where can i get a shifter assy for a 1979 - 82 4 speed tranny
- Aftermarket Intake for a 22R
- 22r internals which years will interchange
- Need a no stinger aftermarket front bumper for 1st gen who makes em??
- Aisin Carb problem
- Can't find the COLOR CODE on my 82..HELP
- 1980 4x2 Restoration
- Left rear brake locking up
- Problems with Weber 34
- L52 Transmission No Neutral
- float sticking on weber 32/36
- knuckle bearing/ races
- oil everywhere
- 22r engine with weber dieseling after shutoff!
- 1st Gen Cab size for a tall guy
- hooker headers.any good?
- 83 Truck is fine at higher RPM's but sputters and dies at idle
- 20r fi swap
- Frame Vin Identification
- 22rblock 20r head questions
- header gasket issues
- V6 brakes
- 1978 Yota pickup/Camper
- 20r throttle linkage
- 81 P/U rotting frame
- Low RPM stumble/hesitation? BOG
- More heater/AC questions
- L52 Standard or HD?
- Can't find these parts anywhere. Can you please help?
- smog system on 22R 82 pickup
- Front axle leaking
- 83 trouble shooting. hit and miss
- transfer case or u-joint noise in 4 lo?
- looking for a stock black bumper 1979 4x4
- distributor cap boot yes or no?
- 83 4x4 Build Project
- After a 4" lift, what is this?
- CHG Light?
- W56 vs R151f
- Headlights not working
- quick wheel question 1st gen
- brake bonks
- Water leaking from cowl. Advice?
- 22r billowing blueish white smoke
- BARN FIND: 1981 Toyota Trailblazer
- Transmission Upgrade or Swap?
- need new springs (no lift) 1980 4x4
- banging from the bellhousing?
- Crossmember Bolts
- Sources for sheetmetal?
- 20 R Electric fan ????
- weird front end noise when driving -1981 4x4
- Has anyone ever heard of this option package on a 1981 pickup?
- 1st gen weight
- Clutch Fork Clips
- 22r only running off battery
- 83 brake problem
- Factory Service Manual!!!!! WOW!!!
- 22R still running rich.
- carb problems
- what happened to tube doors
- sputters uphill
- 1981 toyota project "Sandy"
- OE floor mats??
- What is the best fluid for L52 Transmission?
- Mechanical Fuel Pump
- Crazy Rattle?
- What year had the latch gate?
- Road noise?
- Weber Carb, now where do the hoses go?
- Installed new L52/ceramic clutch, problems.
- emergency brake light wont go off
- Need a 1981 CA vacuum diagram, FSM download/pic is Ideal
- Spacers
- 2wd vs 4wd fenders
- Custom Tonneau Cover?
- Post pics of Wolverines
- 2wd beds VS. 4wd beds
- number /size needed ASAP
- carbs
- EFI help asap: Will '85 parts fit?
- clutch for towing
- 22re engine swap
- tranny swap
- 79 4x4 20R oil pan replacement
- Hard brake line replacement
- 1980 Yota 2wd pu carb flooding out at low idle...
- My 79
- front inner axle seal??
- help diagnose noise please, tranny?
- 32/36 weber running rough at low rpms
- It was the wrist pins!
- rubber mat
- 1982 4WD 5 speed trans & transfer case issue
- valve adjustment question
- I need a link to a good cheap FULL coverage carpet place for an 82 4x4
- new front bumper ends for my 82 Trekker?
- What header should i get
- 81 4x4 wont start when engine cold
- Update on my 82 Trekker
- 79 4spd issue
- Adjusting Weber Carb
- Tailgate Lettering
- Tranny, T-Case and Axle leaks!!!
- 81' 22r 4x4 cold start prob.
- Anyone replaced lower rubber boot? Need ideas!
- Truck Graphics-Type and Color
