Pre 84 Trucks 1st gen pickups
Installed new L52/ceramic clutch, problems.
Old May 29, 2010 | 06:23 AM
dansouthwick's Avatar
I have an 81 p/u. I put in a marlin L52 5spd. and a trail gear ceramic clutch yesterday. Everything is hooked up, bled the cluch slave, but the clutch is not engaging. Without pushing down the clutch pedal i can still shift the tranny. Any ideas what it could be?
Old Jun 6, 2010 | 04:47 PM
Talked to a friend of mine whos a mechanic. He said that maybe i forgot to put the 2 clips that hold the clutch fork and throwout bearing hub together on. If i did would this cause this problem?
Old Jun 6, 2010 | 05:00 PM
suncomb1's Avatar
Order a 1979 Toyota 4x4 truck clutch slave cylinder; its adjustable with thread and locknuts.
Old Jun 6, 2010 | 05:03 PM
INFINITY's Avatar
is this with the vehicle running?
Old Jun 6, 2010 | 05:04 PM
dropzone's Avatar
Fossilized
i used a combination of this: the adjustable piston from the 79/80 with the 1981 slave cylinder.
Old Jun 6, 2010 | 05:11 PM
slacker's Avatar
the "adjustable " part of the slave cylinder (the pushrod) is a fairly easy piece to replicate . This is the only differance between the cylinders
the best way for an "adjustable " clutch ... which may help your problem
Old Jun 7, 2010 | 05:36 AM
83's Avatar
83
Yeah is this with the truck running or not? With the truck off, you will be able to shift through all the gears without pushing in the clutch.
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
