Pre 84 Trucks 1st gen pickups
Water leaking from cowl. Advice?
Old Jun 15, 2010 | 02:28 PM
Rusker's Avatar
Water is now leaking from the cowl into the cabin. Under the grill part of the cowl there is a bit of rust. I can't really access this area so I'm not sure how to stop this from causing anymore damage. The truck is now under a tarp until I figure this out.
Unfortunately, there isn't a cowl delete option like in the newer toyotas so that isn't an option.
What's the next best option?
Old Jun 15, 2010 | 02:59 PM
peow130's Avatar
take the cowl off, as well as the fenders.
i bet you've got a rusthole or two to fix.
Old Jun 15, 2010 | 03:42 PM
slacker's Avatar
cowl is NOT removable on the 79-83's
but you can get to it from the inside .. it will require removing some pieces ..
Old Jun 16, 2010 | 09:07 AM
Rusker's Avatar
It's a 77. I should still be able to access it if I remove the dash?
Is my best option just to weld it? How difficult is it to remove the dash on these older models?
Old Jun 16, 2010 | 05:25 PM
peow130's Avatar
Didn't know that about the earlier models. Well then, i stand corrected.
tj884Rdlx
Aug 28, 2015 12:04 PM
Iceman4193
Jul 15, 2015 04:48 PM
Jonny246
Jul 12, 2015 04:51 AM
Coreyr384
Jul 10, 2015 11:13 AM
Avenged
Jul 9, 2015 07:55 AM
