Pre 84 Trucks 1st gen pickups
emergency brake light wont go off
Old May 27, 2010 | 07:54 AM
senza7's Avatar
Just got an 83 toyota 4x4, after it was smogged the brake light started doing this thing where it wont go all the way off, it just gets a little dimmer when you put the E-brake in, WTF?
Also, are any of you in Oakland CA? Recommend a good mechanic?
Old May 27, 2010 | 08:05 AM
waskillywabbit's Avatar
Check brake fluid.
Kinked's Avatar
i have the same problem on my 91. i think it has something to do with pressure diffrences in the brake system... although that could just be a 2nd gen thing... do you have a sensor on the top of your resevior... if you unplug that does it go away?
Old May 27, 2010 | 09:53 AM
Jeff D's Avatar
Originally Posted by waskillywabbit
Check brake fluid.
+1. My fluid was right on the "low" line, so as the truck warmed up the brake light would eventually turn off. Top it off and hope you don't have a leak somewhere.
Old May 27, 2010 | 05:32 PM
rowdy235's Avatar
Also if there is a charging problem the charge and brake lights will come on, if your charge light is burnt out this could be the problem.
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
