Pre 84 Trucks 1st gen pickups
quick wheel question 1st gen
Old Jun 16, 2010 | 10:21 AM
95yoda's Avatar
I am looking to order new steelies for my truck, they are 15x7 6 5.5 with 4in backspacing. will these fit well? thanks
Old Jun 16, 2010 | 12:34 PM
83's Avatar
83
Hmm...let me see if I can find what my wheels are. A LOT of the wheels out there have the wrong backspacing for our trucks. The ones that were on my truck when I bought it rubbed against steering components. I did a lot of research to find out what wouldn't rub and it actually limited my options since I was limited to a certain backspacing and not everybody carried it. Can't remember what it was now....
Old Jun 16, 2010 | 01:34 PM
95yoda's Avatar
I think its around 4in if I recall. but im sure one of the gurus will chime in. want to get new wheels before my post accident pics can be taken!
Old Jun 16, 2010 | 01:44 PM
4Crawler's Avatar
3-3/8" is stock backspacing:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/22.html
Usually fine to 3-3/4", above that it'll depend on the shape of the wheel as to whether it'll rub or not. Wheel spacers can add some clearance, I run 1/4" spacers.
Old Jun 16, 2010 | 03:39 PM
95yoda's Avatar
I know the stock wheels are 15x6.5" right? and if they have about 3 3/8 bs.....
the wheels I have found are 15x7 and none are lower then 3.75 bs, will that work????
the pattern is 6-5.5 right?
I don't want to order the wrong wheels. thanks
Old Jun 16, 2010 | 04:04 PM
4Crawler's Avatar
Wheels are indeed 6 on 5.5":
- http://www.4crawler.com/4x4/4R_TechI...l#Wheels/Tires
3.75" b/s usually fits, depending on the tire with and diameter, you might run into issues with the tires hitting the front springs at full lock. On stock rims, my 33x9.50s just touched the springs on my '85.
Old Jun 16, 2010 | 07:00 PM
95yoda's Avatar
my tires are 31x10.5 nokian vativva mt. if anyone can link me to plain black steelies with less then 3.75 that would be cool. thanks
Old Jun 17, 2010 | 05:26 AM
83's Avatar
83
Hmm...mine just came from Les Schwab. I'll see if I can find them.
Old Jun 17, 2010 | 05:39 AM
waskillywabbit's Avatar
15x8 with 3.75" bs works. Anything else is too deep and will
rub as so the wheel won't spin at all if even go on period.
Order from 4WP like $45 each.
Otherwise get wheel spacers.
Old Jun 17, 2010 | 08:16 AM
83's Avatar
83
Can't find my wheels at Les Shwab online, but I'll check on my lunch break to see if my receipt tells me much about them.
Old Jun 17, 2010 | 08:22 AM
95yoda's Avatar
wabbit so would a 15x7 and 15x8 3.75bs work the same? should I go with 7 or 8in wide rims? thanks guys!
Old Jun 24, 2010 | 03:04 PM
95yoda's Avatar
hi guys! Got my new black wheels on! Pics to come when I have time to take um. they guy said they are 3.75 bs and they fit good and I see where its close, right by that steering arm on top, but its like 1/4in from that and I drove home no problem. buttt I just read the box and it has 4in bs!?!?! would 4 bs even fit? they must be 3.75 right?
Old Jun 24, 2010 | 10:14 PM
wentz912's Avatar
4 in bs would fit as long as you are running a skinny(ish) tire. They wouldn't clear by much, but that seems to be the situation you are in. If you want to check the backspace yourself, just lay a straight edge across the back of your wheel, and measure from the wheel mounting surface to your straight edge.
Old Jun 25, 2010 | 03:53 AM
95yoda's Avatar
my tire is a 31x10.5 m/t tire. I relooked and its about 3/4in from that steering linkage.
Old Jun 30, 2010 | 02:56 PM
slisdexia's Avatar
I have some wheels I'm going to get rid of. I'll give them to you if you want. I am running 31x10.50s as well and they clear just fine. Don't know the back spacing but they are working just fine. Kinda rusty but not something you can't clean up. Let me know. I'm in northern colorado so shipping may be the limiting thing. PM if you want them
Old Jul 2, 2010 | 05:46 AM
83's Avatar
83
With my old wheels the issue wasn't the tires rubbing. The wheels themselves rubbed.
Jun 1, 2021 01:51 PM
rushw
Jul 18, 2015 01:46 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
87turboPA
Jul 12, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
