1980 toyota pickup lift ?s
im lifting my truck have 3 1/2 in rancho lift and maybe putting on 2 in shackles too but what do i do with the line thats on the rear axle for the brake valve? it is connectoed to the brake valve not sure if i can take it out or do i have to extend the rod some help would be nice thank you
I take it you're talking about the lspv? The thing that's hanging on the frame rail on the passenger side with the metal rod and a couple brake lines coming out of it?
If so, there's a couple options. If the valve is frozen and not letting fluid flow through, you can eliminate it with a manual proportioning valve. If you want to retain the usefulness of it, you can make a bracket that raises the axle end of the rod 4" or so up from the axle. If you don't feel like making one yourself, I believe 4Crawler makes one for the pickups. I went with one of his on my 4Runner because I was short on time and had other projects going when I was getting around to relocating it.
Hope that helps you out, if not please clarify and I'm certain someone will have a creative solution for you.
yep the proportioning valve im not sure if it works the rod is all bent up feels like the ass end is comming up when brakes are hit hard. ill have to test it thanks for the advice
6th Gear
19
12-10-2019 07:31 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
