Pre 84 Trucks 1st gen pickups
Low RPM stumble/hesitation? BOG
Old Jun 26, 2010 | 08:37 AM
citizen_of_the_world's Avatar
I went wheeling yesterday, it was going great. I was driving kennebec pass 11,600ft and started near Hesperus 7500ft. I let my friend drive for a little on the way up. He started to say how it was feeling like it was trying to bog. This is the first pass I have driven in my truck, I told him it was probably just the altitude. I started to drive, it did feel boggy but once again this is the first pass I had done in my truck so far and just went with altitude. I did the pass and on the way down the bog never really left and still hasen't. It seems like it is having problems at lower rpms, it rev's free, but when I put it in gear to go it bogs. I just have to use more gas to go now and keep my rev's higher. What the hell did I do?
Old Jun 26, 2010 | 09:01 AM
GranVille-4crawler's Avatar
could be a carb tuning issue? what motor are you running? thats always helpful to know
Old Jun 26, 2010 | 09:04 AM
redhawk427's Avatar
im willin to bet that's the problem. i just looked at his profile and he has a '79 with a 20r. but im not experience in that old of a yota lol
Old Jun 26, 2010 | 02:13 PM
noot sure if its carb tuning I live about 7500 and it ran before this trail ride. the truck has been in CO for about 31 years. starting to think maybe clogged fuel filter?
Old Jun 26, 2010 | 02:16 PM
redhawk427's Avatar
yeah possible. you could clean the carb too. or fuel pump? just ideas..im no pro on this sorta engine at all lol. just throwin out ideas to consider
Old Jul 5, 2010 | 03:09 PM
Is my fuel filter in my tank before the fuel pump?
Old Jul 5, 2010 | 03:10 PM
Do I have to drop my gas tank to remove my pump and filter?
Old Jul 6, 2010 | 11:07 AM
scottd's Avatar
My fuel filter is in the engine compartment on the passengers side wheel well (this appears to be the factory location). Mine also had a second fuel filter just outside the gas tank (not sure if this was factory or not). There is a screen on the pump (which is in the tank on most if not all 79's I believe) to keep junk inside the tank from getting sucked into the pump.
Rather than drain and drop the gas tank (mine was pretty full when I put in a new pump), I took out the bed bolts on the passenger side and loosened up the bed bolts on the drivers side then just lifted up the bed on the passengers side and propped it up. Then I accessed the pump from above while it was still bolted into the truck.
Old Jul 30, 2010 | 04:41 PM
80banana's Avatar
I'd start with the fuel filter. It's cheap, easy to replace and if you haven't changed it in a while, now's the time. You may find that when you pull it off, a bunch of brown junk comes out. Sometimes all that wheeling can loosen up crud in the gas tank which will get sucked into the filter. Happened to me twice in my old 4WD rig.
Sleaker
Aug 26, 2020 06:03 AM
norcal98
Aug 10, 2015 06:20 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
