Pre 84 Trucks 1st gen pickups
makes grinding noise in 4wd when turnnig sharp.
Old Nov 22, 2010 | 08:51 PM
west_89_'s Avatar
hey we just had our first snow fall and i needed to use the 4wd in my 81 pick up for the first time since i was hill climbing in september. i had it in 4H and was in a parking lot making a sharp turn when i noticed a grinding noise so i did a few laps and found when i turn left or right really sharp it makes a loud grinding noise. i also noticed it seemed to take quite a bit of efort for my truck to move its self and very easy for it to stall out. does anyone have any sigestions or ideas for me to try or know what the problem is?
thanks.
dylan.
Old Nov 22, 2010 | 09:39 PM
874runnersr5's Avatar
jack up the front end and start moving axles/driveline around.
Old Nov 23, 2010 | 11:29 AM
west_89_'s Avatar
umm ok could u maybe give me some detail on what im looking for or what the issue could be.
i tested it more today and found if i only lock one hub it dosent make any grinding noises but if both are looked it does. one of my hubs was seased when i bought it. i pulled it apart and put it back togehter, although it wouldnt click in to lock and whould slid past lock could that be the issue? is something not lineing up causing it to grinding when i turn
Old Nov 23, 2010 | 11:35 AM
82blueyota's Avatar
sounds like broken birf or hub stripped out.you know something is broke.get a rebuild kit from marlin and pull it apart.
Old Nov 23, 2010 | 11:38 AM
82blueyota's Avatar
look at toyospero's sticky front axle rebuild to show you what it looks like in there
Old Nov 23, 2010 | 11:55 AM
west_89_'s Avatar
thanks you!!!! this is what i neede to hear.
cheers
Old Nov 23, 2010 | 11:59 AM
dropzone's Avatar
Fossilized
another possible root cause is more than likely your front wheels were getting just enough traction to cause it to bind.
also check your wheel bearings...
Old Nov 23, 2010 | 04:35 PM
west_89_'s Avatar
could you give me a little more detail on wheel bearings. i did notice that when i turned sharp in snow with less traction its wasnt to bad and then when i hit pavement it grinded really bad. i had the seals on the inner side of the housing re-done and thought that the guy replaced the wheel bearings. is there any type of indecation that would tell me its the wheel bearing if i pull it apart?
thanks.
Old Nov 23, 2010 | 06:30 PM
82blueyota's Avatar
if it was a wheel bearing you would have known it before u put it in 4wd
Old Nov 23, 2010 | 06:44 PM
82blueyota's Avatar
has to be more like a birf,trunion bearing or hub if it was in 4wd when you get the noise.seems like you would have noticed a wheel bearing since sept.
Old Nov 23, 2010 | 08:05 PM
west_89_'s Avatar
ya your right its only in 4wd. now that ive got a prity good idea what it could be ill do some reacher till its gets a bit wormer out to take it apart but ill keep posted. thanks for the help, hard to know what your doing when its your first truck and your 21 with no one to show you.
cheers!
mskalmus
May 28, 2017 07:51 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
mengquis
Jul 13, 2015 10:39 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
