Pre 84 Trucks 1st gen pickups
81 solid axle
Old Sep 20, 2010 | 05:43 PM
Nimyad's Avatar
81 solid axle
ok so i know 81 was the year that they changed the bolt pattern on the spindle for the disk brakes. i don't know if mine is the earlier pattern or the later one. if it is the earlier one what do i have to do to get the later pattern? just replace the spindle or the whole knuckle?
Old Sep 21, 2010 | 06:14 PM
Nimyad's Avatar
nobody ever had this problem?
Old Sep 27, 2010 | 01:31 PM
Sked's Avatar
Its to do with the wheel hub assembly, not the knuckle or spindle. On the earlier ones the rotor is held on by just the lug studs been pressed through. Ones needed for the upgraded brakes also held on by 2 bolts.
If you have 2 small indents inbetween your 6 wheel studs, you have the correct wheel hubs... kinda hard to explain i guess.
Old Sep 27, 2010 | 04:20 PM
Nimyad's Avatar
ok that makes sense. so if i don't have that what do i need to change it, or do i need to change it at all?
Old Sep 28, 2010 | 08:51 PM
peow130's Avatar
Why would you need to change it?
If you're going for new disks.. just ask for ones for an 81.
Old Sep 29, 2010 | 08:06 AM
Nimyad's Avatar
i want to upgrade the bigger vented rotors and they're only avaliable for the later bolt pattern.
80Truck
Sep 15, 2015 04:21 PM
89hilux1
Sep 14, 2015 06:13 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
theduck21
Sep 10, 2015 07:01 PM
