Pre 84 Trucks 1st gen pickups
Dual Cases Triple Sticks!
Old Sep 10, 2010 | 04:52 PM
R.DesJardin's Avatar
Exclamation Dual Cases Triple Sticks!
So I have all my Marlin Crawler parts for my dual setup behind my A340F, I decided I wanted triple sticks instead of cutting two holes in the floor.
First model as shown:
Old Sep 10, 2010 | 04:56 PM
Champ's Avatar
That is so sweet. What options does the triple allow compared to a dual?
Old Sep 10, 2010 | 05:12 PM
Tofer's Avatar
Sponsor
front and rear digs
Old Sep 10, 2010 | 05:17 PM
slacker's Avatar
very cool ...
Old Sep 10, 2010 | 06:04 PM
Gov't Mule's Avatar
yeah...that is super sweet!!
Old Sep 10, 2010 | 06:09 PM
Champ's Avatar
When are you gonna try to get them in?
Old Sep 10, 2010 | 06:19 PM
muddpigg's Avatar
I like the set up. But really it is the exact same as dual case with twin sticks. The only way your going to get front digs is a rear DL disconnect. FROR make one.
Old Sep 10, 2010 | 07:23 PM
Dual set
Yes, it is the same as twin sticks on the back case and a single on the front, it's just that all the sticks are together. Also the rear case is rotated 10deg so regular twin sticks would be at an angle. That's the motivation for making it this way.
Old Sep 11, 2010 | 09:25 AM
muddpigg's Avatar
Originally Posted by R.DesJardin
Yes, it is the same as twin sticks on the back case and a single on the front, it's just that all the sticsk are together. Also the rear case is rotated 10deg so regular twin sticks would be at an angle. That's the motivation for making it this way.
I got twin sticks with the regularly clocked crawl box. How are you going to mount it? what type of Skid plate?
Old Sep 11, 2010 | 09:37 AM
SpecialScottie's Avatar
Whered you get that boot?
Old Mar 18, 2011 | 06:00 PM
Updates
The boots I buy from JB Fab.
Update, been running these all winter, man it's nice to have those levers all in one spot. Also it left room to install a set of cup holders between the seats for my Gatorade.(I wheel alcohol free.)
Old Mar 18, 2011 | 08:33 PM
James Woods's Avatar
So I am sure it has been asked before, but do you have to run a body lift for that setup or does it clear without one? I really like the setup and I think it is the answer to keeping my bench and having duals.
Old Mar 19, 2011 | 09:57 AM
Installs
Here's a link with a lot of info, http://www.pirate4x4.com/forum/showthread.php?t=916481
Old Mar 19, 2011 | 10:32 AM
Dras16's Avatar
Is the purpose of having the rear box rotated to get less drive line angle? Also if I understand correctly it is clocked down not left or right. Am I correct with that?
Old Mar 19, 2011 | 05:03 PM
Angles
Wrong, the prupose is to have more ground clearance, the t-case is rotated 10* up.
Old Mar 19, 2011 | 06:26 PM
Dras16's Avatar
Ok I understand now. Thanks
Old Mar 19, 2011 | 07:30 PM
Nimyad's Avatar
does the case have to be rotated for this setup or do u also have non rotated setups?
Old Mar 19, 2011 | 08:10 PM
Levers
The lever setup in the pics work on either rotated rear case or not. I have a rotated 10* rear, a lot of guys are running dual non rotated cases. Your option.
Old Mar 19, 2011 | 08:34 PM
Nimyad's Avatar
Ok sweet
suppra87
Jul 15, 2021 05:15 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
