- 1982 Toyota: Valve Cover Gasket Replacement
- Buying Engine Have ?
- Steering column issues
- price of a good rebuilt 22r
- 1982 Pickup: ID oil leaks
- 3rd gen box on a 1st gen?
- 76 toyota pickup for sale...
- Rebuilt W50 trans
- vibration during clutch engagement
- Fluid leaks
- Drum to disc swap
- Trekkers in Action Link
- swap20r to 22re
- How much rust is too much?
- Anyone need a Dashpad?
- How hard would it be to...
- the $50.00 paint job
- 81- tach and fuel gauge
- 20 r engine probs
- Great Kansas project on ebay
- 81yota-front end loose
- "harry's you pull it" Hazelton, PA
- what are these parts (rear axle)
- heavy rust on end of SA (knuckle)
- 2wd tire choices on 80 lowered P/U
- bigger front brakes on 1893, which parts to keep?
- cut a little too much (axle housing)
- Different color of manual hubs?
- cracked/rusted frame help
- Random 'chirp' in fifth gear
- removing brackets from solid axles
- I am done...
- Spring help
- Need advice on my 82 Yota
- ?'s or Comments about my profile, ask 'em here
- 1979 Toy 4X4 need info for purchase!
- u-bolt flip on 1983?
- 22r block 20r head
- 1983 SR5 with 22RE swap
- 1982 toy truck with 5 mge swap
- Cool build up thread
- Need advice on motors
- My '83 has pieces of plastic in the oil pan
- driveshaft lenght (shortbed - longbed)
- wiring info for a 1983 SR5
- western WA: can i see your 22R?
- frame differences between 1983 & 1989
- 22r EFI Swap
- weber carb tuning help needed
- 22 short block
- '82 Torsion Turning.
- Missing Brackets from Engine to Bellhousing....
- 82 toyota Front "in the bumper" turn signals
- 79-83 Dash Bezel on Ebay
- New or Rebuilt Engine Advice
- 1983 SR5 tear down begins...
- 1971 LandCruiser chevy 350 replacement Wiring Harness
- my 80 has no spark
- My "new" 1983 pickup
- 1981 Toyota Factory service manual
- bud built frames?
- 92 Toy Pickup bench seat into an 80?
- resurrecting my '80
- Pinion angle + Shackle angle
- HAC Question
- ford probe turbo 2.4l
- 83 yota PU sunroof
- is this the throttle cable bracket?
- air filter/intake options
- I am new to toyota, jus got one cant say i know too much about so far
- Carb Suggestions
- 83 pu slight problem
- 84 seats
- 22r oil leak
- Newbie to Toyota and I need some help with emmisions
- 78 windsheild the same as 81 4x4?
- carb help
- Tranny year identification?
- re-gearing with a 20r
- truck wont start on fuel
- Choke not opening help!
- Running 35's
- Couple kids project
- Hardest to Find Stock Part?
- Weber 32/36 Info and Help Needed!
- 80 Pickup Hi-Steer ?
- my 79 toyota
- Vacuum Question 81 Toy
- Tera Flex Revolver shackles
- New Into Old
- idling problems with my 82 yota
- fuse links???
- 79 What to look for?
- NWOR lifts
- Rear Shock Mounting After U-Bolt Flip
- charging problems!!!
- Radiator question
- Will not hold crank
- Fsm's
- Carbs... anyone running this stuff
- Parting out 83 Toyota Pickup Trailblazer conversion
- head gasket leaking
- 79 diamond in the rough...need some help finding parts!!!
- gas tank differences
- preparing block for head gasket
- Just curious what ya'll are running for timing??
- running badly
- Finally got the lift in.
- My first yota
- LSPV rod?
- Found a Trekker Recently...
- need alittle help with new cam
- Needed ASAP-Banjo fitting for 20R carb
- Birfield eliminator and widening kit
- need more lift
- land cruiser leafs on a mini?
- restoring parts
- A differant type of seat question.
- '82 2WD Toyota needs trans...HELP
- which cam for 22r
- Gas Tank Capacity?
- Tire Fitment?
- Toyota springs
- ID this Carb please- no data tag-
- IFS Steering Box Swap Question
- More Carb Issues
- ted's 261 cam in an 81 head? did I F'up?
- sources for pre 84 22r heads?
- Replacement floor pans
- Headlight relays?
- clutches different 2wd 81 vs. 4wd 82 ?
- 22R bearings
- lift ?'s
- Body parts for my 83 longbed
- Help Needed: Headlight issue
- 2 wheel drive 1 ton toyotas
- Please help! Vacuum lines pix
- 83 mud truck
- tranny problems
- earlier lights on 83
- doors off?
- Clear Or Color Coated?
- First post! Aisan carb on my '81?
- 22R Cali truck?
- I Hate Friends....350 Swap?
- Won't start Carb Issues? 1982 22R
- R151F Swap?
- onw wire O2 Sensor
- Steering Problems...
- t-case e brake help
- 20R Head Gasket
- 1980 Carb problems
- 2" lift springs?
- 82 toy, some charge, hard idle
- Hey 1st Gen Pickup Crowd! **83 & Earlier ONLY** (Post your Pics Please!)
- What Are These Wires For?
- installing 20r cam
- Horse Collar?
- project super cheap
- Power source for stereo and cb
- Highway Speeds
- front springs questions
- bought an 81
- Stock spring replacement on a 1980?
- Dave's 82 Toy Post
- Blowing fuse
- What does this go to????
- questions about 5'' lift and driveshafts.
- to much rust?
- Ignition puzzle
- Tranny Swap Questions
- Carb Questions
- 92 F150 leaf springs?
- Bumper Mounting?
- Main Seal Leak?
- Mechanical To Electric Fuel Pump?
- Drivers Seat belt buzzer question
- Shackle Lift?
- MSD installed
- Picture of bottom pulley
- 83 toyota pick-up
- Power steering for my 83 pickup?
- 1982 2wd/22r => SAS/V6...
- Tranny swap?
- 1983 pickup headlights issue
- timeserts
- 83 lift?
- 84 Doors on An 82?
- Tilt Steering???
- trans switch
- Need advise on seats
- Alternator/Regulator Pin Diagrams
- Wiring Diagram?
- 80 4x4 exhaust leak?
- How Much Gas?
- solid axle help
- 82 Frame Dims?
- Factory Spark Plug Part Number?
- Aftermarket Gauges/Aluminum Dash?
- V6 Brake swap
- Ignition system swap
- tranny problems
- 22r with a 20r head?
- spark help
- 22R Carb adjustments
- color codes for 1980 toy
- looking to buy a 1980 4x4
- V.I.N. question
- 1980 tranny, 1983 22r, what clutch to get?
- 80 4x4 pickup
- have a few questions about my '82
- Front Coil springs - 1977 pickup - HELP
- Ol' Yota
- Custom Alternator Question
- Glass pack?
- Anybody ever try Lucas gear oil?
- Shackle Lifts on a 1980 Pickup
- Tire Fitment?
- 20r aftermarket cams?
- Power Steering Conversion?
- i hate vacuum hoses
- I think I have a 21R...
- Rear Winch?
- 22r has very loud tick
- Dash covers/caps
- 83 vent windows
- to much for the d-shafts?
- Need Bimetallic Valve 1982 Cal emission 22R
- 20R Carb Help
- Looks like I get to hop on the tranny-trouble bandwagon.
- I put truck in 1st and it don't move
- bought another truck today
- Heating and AC
- power steering picture?
- 22R Carberator question
- 1977 Toyota Pick-Up
- engine?? swap???
- 4spd woes...i need help
- Weird noise in neutral, clutch pushed in goes away!
- Aaron's 83 "Project Frankenstein"
- alt. problems
- Weird Tire/Wheel Wobbeling Question
- 1979 yota clutch clip problems
- worth it?
- 83 Toytoa SR5 4x4 drivetrain questions
- help with identifiying a hose
- Motor swap
- Think this would be a good deal? 83 pickup
- Sliding rear window weather strip?
- How do you remove Front Windshield
