Pre 84 Trucks 1st gen pickups
frame differences between 1983 & 1989
Old Aug 9, 2007 | 03:14 PM
HAVOC's Avatar
I know one has a SA, and the other IFS
Would it be possible to swap a cab and bed from a 1983 pickup to a 1989.
I own both trucks, but did not start measuring yet. I was just wondering if anybody has done this swap before. I should be able to do a SAS to the 1989 frame for the 83 axle, correct?
If nobody knows, I'll take measurements this weekend and post them up.
Old Jul 22, 2009 | 06:40 PM
zmc.daniiel's Avatar
Toyota Bed Swapping
Soo..Did you swap the bed ?
I have a 1983 Toyota with very rusted and beat up old Datsun bed. Aside from being beat up, it was very very very poorly "fabricated" to get it to bolt on to the Toyota frame in the first place.
All the salvage yards around don't have any 79-83 Toyota trucks, but there are quite a few 85-89 and newer ones with decent beds on them.
Thanks - =)
Old Jul 22, 2009 | 07:35 PM
jtruck79's Avatar
well i got a 79 toy on a 84 frame and i can tell u that none of my cab mounts matched. in fact i dont have my front rad. support mounts in at all wich sucks. as for the bed i've got 6 points of eight mounted decent alignment. my 4 cab points that are in place arent in the right spot so i just drilled and used dock washers to hold my cab in place good luck with ur swap
Old Jul 22, 2009 | 09:19 PM
dropzone's Avatar
Fossilized
I own both trucks, but did not start measuring yet. I was just wondering if anybody has done this swap before. I should be able to do a SAS to the 1989 frame for the 83 axle, correct? YES
search ya newb yeah an 89 is a 3rd gen but should be close
Putting a 1st Gen Cab on a 2nd Gen Frame:borrowed this from Pirate:
Originally Posted by Erick561
New info. I'm close to putting my 79 cab on my 88 frame. Threw this together this afternoon.
The 84 and 85 front cross member is 1.46 inches higher than the middle of the frame; The 86-95 front xmember is flush with the middle
1st gen Cab mount width eye to eye
  • Front 31.5 inches
  • Middle 47.16 inches
  • Rear 47.56 inches
2nd gen Width eye to eye
  • Front 33.07 inches
  • mid 46.3 inches
  • rear 46.3 inches
1st gen Length, eye to eye
  • Between 1st and 2nd body mount, 44.61 inches
  • Between 2nd and 3rd body mount, 38.5 inches
  • Overall length of cab mount front to rear, 83.11 inches total
2nd gen Length, eye to eye
  • Between 1st and 2nd body mount, 43.98 inches
  • Between 2nd and 3rd body mount, 43.78 inches
  • Overall length of cab mount front to rear, 87.76 inches total
Width Difference between 1st and 2nd gen
Relocating body mounts to fit 1st gen cab on 2nd gen frame
  • Move Front Cab mount .785 inches inward on each side.
I think that the height will be lower than the 79-83 frame if you're working with an 86-88 frame because the crossmember is 1.46 inches higher on a SFA frame, not 100% sure on that though.
  • Middle cab mounts will have to be moved .515 inches outward on both sides and .63 inches back on each side.
  • Rear cab mounts will have to be moved 4.65 inches forward, and .63 inches outward.
Old Jul 23, 2009 | 05:45 AM
83's Avatar
83
OLD thread!!!
Anything can be done if you can weld...there was a guy looking at a first gen truck that was on the body of some later model...can't remember but it was basically a first gen with IFS and EFI. You can throw a subaru body on an '89 frame if you want. But no, the cab mounts won't line up. Have to fab.
Old Jul 23, 2009 | 06:02 PM
dropzone's Avatar
Fossilized
oh crapdid not even notice that a newbie playing thread archeologist dug one up that old...
Old Jul 27, 2009 | 05:35 AM
83's Avatar
83
Yeah it happens now and then. It always throws me off, too. Although I think in this case somebody was actually looking for an update..
Old Jul 27, 2009 | 06:30 PM
Ahh.
Yes I was looking for an update.
And also not about the cab mounts, rather the bed mounts from a 1989 bed to a 1983 frame.
I can't find a 1979-1983 bed to replace the bed on my 1983 pickup. But I found some year toyota bed that worked. The body lines don't match up, but it bolted down ok.
Thanks.
I forgot how much I loved forums *le sigh =)
Old Jul 27, 2009 | 06:55 PM
GenXr's Avatar
FLAT BED IT! Search for the flatbed thread. There are tons of cool pics in that one.
young buck
18
Aug 27, 2018 02:40 PM
gieselman
Mar 20, 2016 04:34 PM
Gone Fission
Jul 31, 2015 03:58 AM
jgallo1
Jul 22, 2015 04:21 AM
yourrealdad
Jul 21, 2015 11:13 AM
